Xray T4 '13
#2897
Any tricks on rebuilding the shocks? First time with 25% rebound no problem following owners manual but after a few weeks later I can't seem to get it to work again to achieve same rebound. Tried following same instructions again with no luck. I heard the stock bladders swell up over time? If any of you are rebuilding it differently with success please share
#2898
#2899
#2900
Anybody have any advice on reducing off throttle oversteer? Finding the rear swaying out too much coming into the corner and wiping too much speed.
#2901
HI,
I installed today a standard servo Orion 1017
but it doesn't fit good, I had to remove all the shims that I used with the first low profile, removing the adhesive label from the servant and given a narrowed down to the plastic of the steering group that touched but
I have little space, the manual talks about a minimum of 0.5mm of space
i removed the shim on servo but touch
T4 is built only to serve low profile?
#2902
hi all,
i have a question regarding the upper clamp position in the front... the T4 manual says that, as initial asphalt setup, you should use position 1 on both front and rear... but the same xray, in the "T4 basic asphalt setup sheet", says that you should use position 2 in the front upper clamp.... and most setups i see on the net also are on position 2 in front... can someone clear this aspect ? it would help...thanks,
#2903
FOR SALE T4 - NEW. Ran 2 packs on carpet. Not a scratch on it. Spektrum LP 6070 servo installed. Comes with everything in kit. Body posts not even cut down. Upgraded Front Xray bumper. call me/text me 518-495-0703 for pics. $440 with Servo.
#2904
HI,
#2905
We noticed last night there appears to have been a running change to the servo mount. The older kits have one "nipple" that keys into either the chassis or the brace that goes across the top of the servo. Newer kits have two nipples.
Now you know about your XRay's nipples.
#2906
#2907
#2908
Edited - will sell without servo as well.
#2909
#2910
