Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
Old 12-21-2016, 08:46 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
RB6.6 Kyosho America Product Page: http://www.kyoshoamerica.com/ULTIMA-...T_p_24505.html
RB6.6 Manual http://www.kyosho.com/jpn/support/in...A_RB6_6_IM.pdf
RB6.6 Kyosho Youtube https://www.youtube.com/watch?v=vW_sR667utY
MSRP $639 MAP $399.99
New RB6.6 parts (compared exploded views, prices and links are Kyosho America):
Chassis:
  1. Main chassis - UM731 - $125.99
  2. Side guards - UM732 - $9.99
Battery Holder:
  1. Battery plate - UM733 - $8.99
  2. Battery foam - UM741 - $7.99
Rear Bulkheads:
  1. MM3 and Laydown - UM740 - $9.99
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
3 Gear Transmission (MM and RM):
  1. Transmission - UM734 - $10.99
    • transmission cases
    • spacers
    • caps
    • plastic FR & RR suspension hangers
  2. Gear Cover - UM735 - $6.99
Laydown Transmission (3 and 4 gear possible):
  1. Transmission - UM736 - $10.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  3. Motor plate - UM738 - $18.99
  4. Gear cover - UM739 - $6.99
Body:
  1. Blade body - UMB05 - $27.99
Optional Parts:
  1. Lightweigt Blade body - UMB05LW - $31.99
  2. Aluminum FR suspension hanger - UMW705B - $28.99 (may be able to file UMW705 to fit)
  3. Brass FR suspension hanger - UMW725B - $30.99 (looks more different than UMW725..someone confirm?)
Typical Upgrades for new RB6.6 Buyers
UMW701 Aluminum Steering Plate (RB6)
UMW702 Aluminum Crank Arm (RB6)
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
UMW705B Aluminum Rear Sus. Holder (RF/RB6.6) or brass UMW725B
UMW707 Aluminum Rear Sus. Holder (RR-Mid)
Nice to have:
UMW723 Aluminum Front Sus Block (Type B/10g/RB6/RT6/SC6).
Aftermarket Parts:
Front Wing: https://www.prolineracing.com/perfor...mount-alum-rb6
Print Wikipost
Old 12-02-2012, 06:12 PM
  #3061
Mxer59's Avatar
Trader Rating: 114 (100%+)
What are you guys running for gearing in 17.5 in rear motor
I have a Gen2 Tekin motor
Mxer59 is offline
Old 12-02-2012, 06:32 PM
  #3062
B00t13g's Avatar
Originally Posted by t8rtot
Best pricing at speedtechrc
I always forget to mention them. They have great prices and great customer service. Just made an order with them actually.
B00t13g is offline
Old 12-02-2012, 06:44 PM
  #3063
skidooracer's Avatar
Trader Rating: 26 (100%+)
thanks guys, i jus got my car and i havnt run it yet but jus being prepared i made the switch from AE....
skidooracer is offline
Old 12-02-2012, 07:33 PM
  #3064
CanyonCarverR1's Avatar
Trader Rating: 13 (100%+)
Originally Posted by Posvar
Has anyone used the orion wts lipo with weights? I am interested to hear feedback if so.
Matt
I've been using them, but mostly with no weights. I did try some weight towards the rear of the car when I was trying to correct something. I have since removed the weight and corrected the problem with suspension changes. I think the weights aren't needed, and are just a band-aid to a handling problem, but I like having them in my box just in case I start bleeding
CanyonCarverR1 is offline
Old 12-02-2012, 07:57 PM
  #3065
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Originally Posted by Mxer59
I got that notchy feeling out of my tranny, thanks for all who replied with help.
Are there any must need upgrades for this car?
Replace the ballstuds that are not long in length when it comes to threads. Pickup some of the longer ones. The short ones can be found in the front caster block and someplace else (memory is failing me right now). Otherwise, they tend to pull out.
Kraig is offline
Old 12-02-2012, 08:09 PM
  #3066
fastestwon's Avatar
Trader Rating: 15 (94%+)
Default PDF file of race
check it out
File Type: pdf
fastestwon is offline
Old 12-02-2012, 08:25 PM
  #3067
silvalis's Avatar
Trader Rating: 29 (100%+)
I was running 34/69 on a Fantom Ion3, until I did something dumb. Used a kimborough associated spur as per what Cpt keeps saying.
I've got an avid triad and a reedy incoming. Going to start at around 30/69 or 72 then go up.
silvalis is offline
Old 12-02-2012, 09:54 PM
  #3068
Mxer59's Avatar
What weight oils are you guys running on stock setup?
Mxer59 is offline
Old 12-03-2012, 06:02 AM
  #3069
eper's Avatar
Trader Rating: 14 (100%+)
the only upgrade this car needs is a endless supply of charged batteries so you can keep turning laps
eper is offline
Old 12-03-2012, 06:06 AM
  #3070
Mxer59's Avatar
well can't wait to get her on the track, was curious as oil weights to run? On my b4.1 big bores I did 30-27.5
Mxer59 is offline
Old 12-03-2012, 07:52 AM
  #3071
Jamison R's Avatar
Trader Rating: 66 (100%+)
Jamison R is offline
Old 12-03-2012, 08:28 AM
  #3072
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Too many variables to give you the "sweet spot" on gearing. How much endbell timing you are running, how heavy your car is, what rotor you are running, and how large your track is can vary your timing by quite a bit... and the gen2 tekin motor is probably going to be about your least popular motor at this point considering it's so new. I don't know a single person running one at either of my tracks. Having said that, here is where I run. With this combination, the 31/69 is the sweet spot. 30 is slower, and so is 32. It can also vary motor to motor of the same model. (although probably not much).
Fantom APEX 17.5
Fantom 4500 shorty lipo
endbell timing maxed
12.5 HT rotor
31/69
Car is blistering fast for a 17.5. This weekends race I ran a fast lap of 14.4... Mod fast lap for the night was 14.3 in a b4.1
Cpt.America is offline
Old 12-03-2012, 08:30 AM
  #3073
Originally Posted by silvalis
I was running 34/69 on a Fantom Ion3, until I did something dumb. Used a kimborough associated spur as per what Cpt keeps saying..
Is there a problem?
Old 12-03-2012, 08:32 AM
  #3074
t8rtot's Avatar
Trader Rating: 14 (94%+)
I think he's stating his choice in spur, to each that gearing. per your recommendation
t8rtot is offline
Old 12-03-2012, 08:40 AM
  #3075
aahh.. at first I read it as he was saying something dumb happened because he used my recommendation I see now.
