Durango DEX210 Thread >
Like Tree80Likes
Old 09-24-2012, 07:50 PM
  #7921
Trader Rating: 15 (100%+)
Default bearing
Originally Posted by underway
Anybody seen this where the thrust washer will not fit onto the screw? This is the second issue with this build that has brought me to a halt...
Try putting the other side of the on first.
mdhyams is offline
Old 09-24-2012, 07:56 PM
  #7922
DBL15's Avatar
Originally Posted by mdhyams
So I am running the D3 with 28/75 and 55 deg of boost. Does that sound about right or do I need more gear?
sounds about right mate just remember to check your temps for the start and middle and then end of your run
DBL15 is offline
Old 09-24-2012, 08:05 PM
  #7923
retsoorkcuf's Avatar
Default sand it
i had the same issue and i took sandpaper to the shank were the threads end and the shank starts if you look with a magnifying glass you can see a small ridge were the threads end i just sanded till it fit and ive had no problems diff wise
retsoorkcuf is offline
Old 09-24-2012, 08:09 PM
  #7924
ekt
ekt's Avatar
Originally Posted by dubum
I bought my son the RTR for his B-day on Saturday and we took it to the track on Sunday. I don't know why, but the front of the chassis is already broken at the first 4 screws. It really sucks as I thought this was going to be a pretty durable vehicle. He wasn't abusing it that I know of, just typical track time. He is not a newb and knows about throttle control and proper jumping procedure. Just putting that out there
(2 questions)
1. Does anybody think Team Durango will warranty the chassis as some sort of defect? I mean c'mon, it's crazy!
2. What extra parts would I need to convert to the aluminum chassis? As everything on the RTR is molded into the plastic chassis.
Thank you
I would contact Team Durango at [email protected].
To convert to the aluminium chassis you would need -
MAIN CHASSIS PLATE Part No: TD320125
CHASSIS SIDE POD SET Part No: TD320122
3x10mm CS Screws x12 For mounting the side pods and rear suspension holders.
And probably a new body since the RTR has a +8mm chassis
DEX210 CLEAR BODY SET (INCLUDES DECALS & MASKS) Part No: TD402009
I think that is it.
ekt is offline
Old 09-24-2012, 08:11 PM
  #7925
Default rear camber link mounts
took my dex210 to the track today and broke the rear camber link mount on the tranny it broke pretty easy i was wondering if there is a mod i thought i heard some time ago about a plate mod but cant seem to find it in this thread
Old 09-24-2012, 08:16 PM
  #7926
ekt
ekt's Avatar
http://www.tresrey-usa.com/tresrey-a...ex210-dest210/ is what most people use.
ekt is offline
Old 09-24-2012, 08:36 PM
  #7927
Default thanks ekt
Originally Posted by ekt
do you know if this will work with mid motor config
Old 09-24-2012, 09:07 PM
  #7928
ekt
ekt's Avatar
This is how you would mount it for mid motor, would need a couple spacers to move it up so you don't need to cut off the default mounts.
ekt is offline
Old 09-24-2012, 10:17 PM
  #7929
Trader Rating: 16 (100%+)
I had the same issue. The two washers are different sizes on purpose. From what I have read here you should put the tighter one on first. I had a tough time getting the tighter washer on but it eventually slid over the bolt if you get it just perfect.
What was the first thing that brought you to a halt?
zipperfoot is offline
Old 09-24-2012, 11:36 PM
  #7930
slow_jun's Avatar
Trader Rating: 14 (94%+)
made mine.
slow_jun is offline
Old 09-25-2012, 04:53 AM
  #7931
Jeff Werner's Avatar
Trader Rating: 30 (100%+)
I like the White ball cups. Are those losi? What ballstuds did you use with them?
Jeff Werner is offline
Old 09-25-2012, 08:36 AM
  #7932
jackcarter3's Avatar
After the process of elimination smash and I figured out the two idler gears must be out of round a bit. I dremeled a small amount of material out of the rear upper shaft hole to allow a little play and the gearbox is great. You can feel the out of round on the gears though. Just had to remove everything one by one and shim and re shim until we finally figured it out. I really like the mm4 layout, hope it works on our track.
Originally Posted by Randy_Pike
There should be no clearance issues running MM4 over RM3. Start removing each individual part until the case halves fit properly. My guess is that either the bearings in the mid gears aren't fully seated or you have more diff shims than you think...the thin copper ones are super thin.
jackcarter3 is offline
Old 09-25-2012, 09:00 AM
  #7933
Trader Rating: 79 (99%+)
I havent experienced a binding on my transmission, and I have been running RM4, almost from day 1. Machining plastic, may not be the smartest thing.
Raul Garcia is offline
Old 09-25-2012, 09:03 AM
  #7934
Cain's Avatar
Trader Rating: 294 (100%+)
Raul, if you have any input for onroad, please look at my post on the speed passion thread in the onroad section. Thanks!
Cain is offline
Old 09-25-2012, 09:16 AM
  #7935
It was a last resort thing and this is a spare car I am building up. Tried everything but different idler gears as I didn't have any extras. When I used to term dremeled, I used it lightly. Took about .5 mm off of the back of the rear mounting holes to free up the idler shaft and allow the gearbox to spin freely. Didn't get crazy with the dremel or anything. Been doing this over 25 years and have a lot of experience. I hated to do it but it was a last resort move. Nothing is compromised.
