Go Back  R/C Tech Forums > General Forums > Rookie Zone
Stupid noob question >
Old 10-06-2017, 10:37 PM
sum guy's Avatar
Default Stupid noob question
So as you know, there's always an amp rating on an esc (60a, 120a, etc). What does this mean though? Been in the hobby for a while and I really don't know the meaning of this rating lol.
sum guy is offline
Old 10-07-2017, 03:40 AM
DirkW's Avatar
They often even have two amp ratings.
In theory, they give you the maximum current the ESCs can handle without getting damaged. They usually give the continuous (and on many also the short time peak) rating.
Whether or not ESCs can really handle e.g. 160A for a long time and/or >700A in bursts is up for debate. Some components in them probably will be able to handle these currents - but the whole unit, as installed in the car (with all the wires and plugs in the game)? I wouldn't bet on it.
DirkW is offline
Old 10-07-2017, 06:23 AM
sum guy's Avatar
thanks.
sum guy is offline
Old 11-20-2017, 09:58 AM
Just make sure the esc you have is rated for the motor you are using. A 17.5 motor requires less amps than say a 5.5 motor.
Mononga is offline
Old 12-01-2017, 06:00 AM
Hobbywing has good reliable equipment.
patyroach is offline
Old 12-01-2017, 08:07 AM
kevinatfms's Avatar
As others have stated above if the ESC is rated at 120amps its the continuous rating the ESC can handle for an extended period of time. The burst rating is the highest draw that the ESC can handle for a short period of time before it overheats or overloads.
Although 700amps is an insane amount of power and I believe most of the RC connectors that people use today will melt right around 300 amps or so. I know Anderson Power Poles and original Deans connectors are good to more than 350 before things start to happen(melting/SC/wire desolder). The larger XT60 and XT90 connectors can handle more from what I have heard.
kevinatfms is offline
