RPM bearing blaster
RPM bearing blaster
whats the use??
and how wil i use it??
its for cleaning your bearings, if u use it you will need motor spray with the small add on tube for inserting inside the bearing blaster. Make sure to wear safely googles or at least turn your face away when u spray into it, motor spray can spray back at you. After they are clean and dry apply drop of oil
The bearing blaster is an absolute must have. It forces motor spray all the way through the bearing, blasting it out the bottom. As Joel Lagace said, you should re-lube the bearings after you are done spraying.
There shouldn't be any motor spray flying at you. If there is, you need to either insert the tube further into the nipple or push the top part down harder.
Have the Bearning Blaster and LOVES it! I run off-road and in between runs I clean my bearings when cleaning my tires. It isnt necessary to remove the bearing seal during each cleaning but you should to give them a thorough clean whenever they feel gritty. Always add a drop of oil when you are done.
