Go Back   R/C Tech Forums > General Forums > Rookie Zone
Like Tree6Likes
Old 06-23-2017, 03:52 AM   #1
Default After run oil substitute
I have a little problem my local HS doesn't have any after run oil what can I substitute it for, some say WD 40 or Singer oil
Need help please
Thanks in advance
Lalous is offline   Reply With Quote
Old 06-23-2017, 05:53 AM   #2
On our boats we always used FAI fuel (0% nitro airplane fuel) through the carb, then air tool oil the same way as after run oil.
anthonyscardina is offline   Reply With Quote
Old 06-23-2017, 07:40 AM   #3
Super Moderator
racer1812's Avatar
Trader Rating: 30 (100%+)
nitrodude, Bud and TeamSkunkwerks like this.
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 06-23-2017, 11:00 AM   #4
the rc guy's Avatar
WD-40 leaves a residue behind... i use sae 30 wt.. also Z-max..marvel Mystery is also good to use
the rc guy is offline   Reply With Quote
Old 06-23-2017, 08:03 PM   #5
I use Marvel Mystery oil.
You get a lot for a little.
TLR 8IGHT Nitro Buggy RTR/3.0
Kyosho Inferno NEO 2.0 RTR (belongs to my son)
RC10GT Factory Team w/ Trinity/Picco .12 - retired
Nitro TC3 w/ OS .12CVR - retired
Evoking1230 is offline   Reply With Quote
Old 06-24-2017, 12:16 AM   #6
fuel has oil, after oil is just reaching into your wallet
sponsored by : Stashko Speed Shop
Everingham Electronics Emporium
Webster RC Parts Warehouse
Anderson Zap Ties
- overkill is a good thing -
buster8787 is offline   Reply With Quote
Old 06-24-2017, 03:08 PM   #7
Thanks for the info will see what i have available near me
Old 06-24-2017, 07:18 PM   #8
Bud
I use 50-50% marvel and atf. Either one by it's self would work just as well.
Bud is offline   Reply With Quote
Old 06-26-2017, 04:22 AM   #9
the rc guy's Avatar
not ... after run oil is a must .. get what you can find in peoples suggestions... buster ever hear of rust?..
Bud likes this.
Old 06-27-2017, 07:46 AM   #10
Fuel does have oil in it, but the nitromethane attracts moisture, that's why we ran the 0% fuel thru the carb.
Old 07-05-2017, 01:05 PM   #11
Send a message via ICQ to iliveonnitro Send a message via AIM to iliveonnitro Send a message via Yahoo to iliveonnitro
Anyone know if standard 2-stroke oil from walmart would do the same thing?
btw, i only used after-run oil when I wasn't going to run the engine in the next 2-3+ weeks. If your LHS is out, just make sure you run the car once every week or two and you won't have to worry about anything.
iliveonnitro is offline   Reply With Quote
Old 07-05-2017, 03:43 PM   #12
For what it's worth, my 1/8th scale buggy sat in non-climate-controlled storage for about 6 years and fired right up the other day. All thanks to FAI and air tool oil.
Old 08-10-2017, 06:01 PM   #13
snuvet75's Avatar
Trader Rating: 14 (94%+)
Come on guys. Whatever after run oil you get, it's dirt cheap. Use it after every use. It only takes a few drops and even a small bottle of RC specific after run oil lasts for a long time. You definitely don't need to pour a large amount to the point you'd have to buy a new bottle every month. I use a small bottle of exceed oil (I think it's 1 oz) and it lasts for more than a year. A drop from the bottle is 1/15 cc. 1 oz is 32cc. If you put 5 drops after each race, it's 5/15cc= 0.33cc. It means 1oz bottle lasts for about 100 races. Even very expensive after run oil like $20(I don't even think it exists though) divided by 365 days= 5 cents a day. I'm sure you can afford that when you guys buy $3-500 dollar engine. Sorry I'm direct but it's true, no?
Capricorn LAB C03, Serpent Project 4X, Airtronics M12, Airtronics Super Vortex
snuvet75 is offline   Reply With Quote
Old 08-12-2017, 01:10 AM   #14
Ovaloldtimer's Avatar
When nitro evaporates it leaves an acidic white dust, this is why after run oil is important if the car is going to sit.
A few drops of Mystery oil is all that's needed.
Ovaloldtimer is offline   Reply With Quote
Old 08-12-2017, 06:22 AM   #15
The proper way to prep an engine for storage and the best way to truly oil it to actually protect it.
Run engine out of fuel with fuel disconnected from carb. Try to restart engine several times until it doesn't fire. Leave piston at BDC for a couple hours. Take your favorite oil and put a healthy squirt down the glow plug hole and a few drops down the carb. The idea here is to flood the internals with oil AFTER the fuel residue evaporates. If you oil it too soon, the oil will trap the corrosives underneath it. If you use fuel with a good dose of castor in it, you don't need to do any afterrun oiling to protect from rust or anything for a measureable amount of time.
My favored oils:
- Dexron transmission fluid mixed 10:1 with Seafoam
- Sewing machine oil (same thing as 3-in-one oil basically)
- air tool oil (provided it has corrosion inhibitors)
I prefer the ATF/Seafoam mix because it helps keep varnish and carbon minimal when using a heavily castor based fuel.
A few drops of oil doesn't do crap FYI. You need to almost need to fill it half full, swish around, and dump out.
SlowLST2 is offline   Reply With Quote
substitute for after run oil rc_in_mexico Nitro Off-Road 36 04-25-2010 03:00 PM
After run oil? srowell3 Nitro On-Road 43 02-22-2007 07:51 PM
Am I leaving anything out or any substitutions/recommendations... MCF Monster Trucks 26 02-11-2006 11:16 PM
