Some advice on purchase from a newbie
Hi all, first time post here and I need some help.
I am about to purchase a 1/10 buggy and there are a few options.
Option 1 - 7.2v 3600 mAh battery with a 3300kV motor
Option 2 - 8.4v 4200 mAh battery with 2726kV motor
Option 3 - 11.1v 3900 mAh battery with 2726kV motor
I calculated that the option 3 would be the fastest at 30192 rpm.
One question I have is - which of these options would run for longer (longest battery life assuming running without stopping until and max recommended discharge)?
Another question I have is, could I just replace the 2726kV motor with a 4800kV or 5200kV motor without issue or is it not a straight motor swap? Also how would the extra current draw affect how long the 3900 mAh battery would last?
If I have posted in the wrong thread please accept my apologies and guide me to the right place.
I know most folks who get into this want to go fast from the get go but I'd strongly suggest starting with a 17.5T just so you can start learning how to handle the vehicle.
I only just recently got back into this and went with a 6T but within a day switched to a 17.5 just so I could figure out how to drive my buggy properly.
Take the time and put the effort into getting some solid foundation skills and the faster turn motors will easily be more enjoyable !
If you give us some info on what vehicle you're getting maybe some of us can offer some suggestions to start with
Thanks for the help. Here are some specs from the sellers online store. As with most of these online avenues the specs are somewhat incomplete. I also seem to have transposed the motor numbers for option 1 and 2 above.
1. HSP 94107TOP-10722 1/10 White 2.4Ghz Brushless 4WD Off Road RTR RC Buggy
Quick Overview
HSP 2.4 Ghz Radio System.
4WD drive system.
High precision Brushless 2720KV and Waterproof ESC.
6 KG Hi Torque Steering Servo.
Oil filled aluminum capped shocks.
Oil serviceable gears built-in high quality bulkhead.
Precision front steering system featuring quick turning response.
7.4V 3600 mAh Lithium Polymer Battery
Off road knobby tires with spoke wheel rims.
Specifications
Electric Power Off Road Buggy.
Length: 400mm. Wheel Base: 275mm. Ground Clearance: 26mm. Height: 160mm.
Gear Ratio: 8.038:1.
Motor: Brushless 2720KV
Wheel Diameter: 86mm.
Wheel Width: 32mm Front - 40mm Rear.
Chassis: ABS Monocoque Chassis.
Rechargeable battery type: 7.4V 3600 mAh 3S Li-Po.
2. HSP ACE Mean Green 2.4Ghz Brushless 4WD Off Road RTR 1/10 Scale RC Buggy
Quick Overview
HSP 2.4 GHz Radio System.
4WD drive system.
High precision Brushless 3300kV and Waterproof 60A ESC.
6kg Hi Torque Steering Servo.
Oil filled aluminum capped shocks. (color coded green)
8.4v 4200mAh Ni-MH battery. (Optional Up-gradable 7.2V 2S 30C Li-Po not included)
Specifications
Gear Ratio: 1:7.38
Motor: Brushless 3300kV
Wheel Diameter: 86mm. Wheel Width: 32mm Front - 40mm Rear.
Rechargeable battery type: 8.4v 4200mAh Ni-MH battery.
3. HSP 94107TOP-88801 R-SPEC Stealth 2.4GHz Brushless 4WD Off Road RTR 1/10 Scale RC Buggy
Quick Overview
4WD drive system.
High precision Brushless 2726kV and Waterproof ESC.
Oil filled aluminum capped shocks (color coded red).
11.1V 3900 mAh Lithium Polymer Battery
Specifications
Motor: Brushless 2726kV
Rechargeable battery type: 11.1V 3900mAh 3S Li-Po.
Quick Overview
4WD drive system.
Specifications
Quick Overview
4WD drive system.
Specifications
Gear Ratio: 1:7.38
Quick Overview
4WD drive system.
Specifications
I think any of those 3 options are going to be equally as bad. It doesn't really matter which one you choose. I've seen people sell complete RTR B5's and 22 2.0's for $200-$250 you would be much better off going that route. Unless you live in a country where that stuff is hard to find.
What do you want to do with the car? All-terrain bashing? Track driving/racing? Speed runs in the street in front of your house? We can almost certainly get you into the ballpark with a recommendation for a better, more focused car that, even if it costs a bit more at the start, will cost a lot less and be more fun in the long run.
I see it happen all the time. People want to get an inexpensive car to get into RC. So they get something like this. Then a few days later the esc burns up. Then they replace it with a $50 hobbywing, then they break an arm so they get aluminum arms for the whole car, then other things start to break. Then the servo breaks. Then the battery puffs up, biffs blow out. And they start "upgrading" everything to a point where they have $500 in the car because buying something a little better was out of their budget. I know a guy that has over $300 in a 1/18 scale latrax short course truck.
That's a scary vehicle, I wouldn't want to have to find replacement parts for that.
Hey @bertzz99 - what's your dollar range out the door? Perhaps we can put together something solid for you that'll work for what you want.
If your looking to get a car just for bashing, take a look at the 1/14th scale LC Racing/tacon, their a little smaller, but the brushless cars are fast out of the box and reliable, have had a couple SCT truck for over a year and had to replace one front a-arm and a steering servo, parts are super cheap,the brushlees cars come stock with an aluminum chassis, big bore aluminum shocks and metal gears and full bearings, radio work, but aren't the best, we run 2200 mah lipo batteries and get 30-35 minute run times.
cost on the LC Racing/ Tacon cars are $170-200 RTR, we got ours from NitroRCX for $170 less 20% on a fathers day special!!
I tried to stay on a budget with mine but it completely went out the door and I decided to just get what I want and not worry about cost! I was driving myself crazy. But one piece of advice is I would see what your local hobby shop has. It sucks to only be able to get parts online. I got a hobao hyper ss truggy running 6s. But if I could buy again would probably get a traxxas
