Go Back  R/C Tech Forums > General Forums > Rookie Zone
sensored brushed motor the + and - bottom of can >
Old 01-24-2017, 01:53 PM
  #16
Originally Posted by Metalsoft
It is most likely over heating because of the stress you are putting on it.
I would try to find smaller gears coming from the motor to help control heat.
When you say over heating, is it really over heating? 150 deg is ok for brushless motors.
Are you running it with the Audrino or are you controlling the ESC with the Audrino?
If you are running it directly that is your problem because of the phases.
If this is what you want to do, then I would switch to brushed motors just for sake of being easy on a prototype build.
What size Brushless motor is it?
BTW the + increases RPM, the - increases torque.
Thats the thing tho, there is nothing connected to it. each motor is connected to a wheel, so no gears involved. however in this case, there is no load on the motor and its getting hot af. im controlling it with arduino. I have another motor wil runs perfectly fine, no heat. the other motor, it gets too hot to hold (nothing connected to it so i used my hand to keep is up)
Motor:https://hobbyking.com/en_us/turnigy-...-approved.html
esc: https://hobbyking.com/en_us/hobbykin...1-10-1-12.html
masterfo is offline
Old 01-26-2017, 01:27 AM
  #17
i found the problem, i need one of the motors to b reversed so i switched 2 wires while in sensored mode. according to a few helpful people in this fourm, that seemed to be the problem. im also using an arduino
my next problem is to find out how to get 100% reverse :/ they r telling me to get a programming card. but what does a programming card so? if i know how a programming card does it, i can replicate it using the arduino or something
masterfo is offline
