2WD Buggy
2WD Buggy
Hello RCTECH,
I am not new to RC, have a slash, merv and Axial Wraith. However looking to step into the race scene. I want to start out with a 2wd Buggy. Which one would be a good starter, something that isnt going to break the bank? we have a cly track where I am. Thanks for the help.
Chris
Chris
Hello RCTECH,
Chris
Chris
I have a B5M Lite kit and I have put that thing through a lot. Tons of collisions with other buggies and a few 15FT jumps while doing some bashing sessions. The Lexan wings will crack pretty easy, but they protect the rest of the car and are cheap to replace.
Hello RCTECH,
Chris
Chris
I'll second the B5M Lite. Been driving the short course trucks and the buggy is a very fun change of pace.
I could just push serpent haha because its what i have found (after serious trying and tuning and alot of hours of tweaking) to be what suits my driving style, but honestly they are only good for advanced drivers, so i also second thenmotion for the b5, as it is an easy OTB kit to drive, but there are others like ,losi,durango,team C, that have a reliable buggy for minimal costs...but i think its a matter of trying what you like at a local track if you can find somepplwith diversity and see if they will let you try it and feel what you think you like between the cars, because buggy is a very finese and precise class and it takes some getting used to. Good luck and happy hunting
I love 2wd buggy and it is a good starting point for any racer , as that is said Rb5 isa good buggy and is cheap to find .http://www.rctech.net/forum/r-c-item...c-edition.html
Thanks for all the advice, settled on a B5m roller...going to track soon and start hanging out on race day.....
I agree with visiting the track you plan on racing at. You want to get a kit that is popular at your track. That way you can get help when needed. You also need to think about parts availability. You want to get a kit that you can get parts for. As for a specific recommendation, I would suggest a B5m or B5.
is there a huge difference in handling with the b5m having a mid motor? I would think all the weight being between the wheels would improve handling and jumping
I ran a b5 all winter on carpet and could not keep the front end down even with slipper squealing for the first 5 ft. I finally gave up and bought the mm conversion kit. Haven't had a chance to run the b5m
The mid motors handles quite a bit differently. It tends to oversteer less, but when it does oversteer it will want to spin out much more easily. Usually you want to keep a bit of extra throttle in the corners with the mid motor as it help keep the weight shifted to the rear end of the car. This usually makes it a tad faster in the corners than the rear motor, but it takes time to learn the correct amount of throttle without spinning out. It is much more sensitive to suspension changes as well.
Just came across this thread hate to revive things but: We have an oval track that will be racing Vintage Mod and Street stock class, they require a 13.5t REAR motor configuration. So be sure mid motor won't restrict what class you run... now I'm trying to decide between a used B4.1, B4.2 or get a new B5 rear motor kit...dunno if there is a ton of differences between them.
