Motor tooo HOT
#16
Super Moderator
I looked at the
SCT-PRO-C3
81040260 (Black)
and
the JS2
Can I run the gears that came with truck
It had a Titan 12T and it ran great
Not sure what pinion but I think 19 and the big one 86 or 90 I have them both
I have a 14 pinion also
Can't wait to throw dirt (If it ever stops raining)
You guys realy make this fun cause if it was not for all you guys help
I would have put my truck in the back of the barn !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
So thanks for the advice
And MANY MANY Thanks to "RCTECH" web page
SCT-PRO-C3
81040260 (Black)
and
the JS2
#17
OMG !!!!!!!!!!!!!!!!!!
Grizzbob
Got the motor (C2)
got a 17 t pinion cause the output shaft is 5mm and i could not find a 16t
Got a Lipo 3S
all installed waiting on the rain to stop here in OK
But Sunday morning I took it for a test drive on the road
OMG !!!!!!!!!!!!!! WOW !!!!!!!!!!!!!!!!
it looks like it is about 1.5 times faster
I had to run it on my track , it is just a little wet that morning
shoot its WOW !!!!!!!!!!!!!!! dont know what to say
so many thanks for the help and advice
I hope I can help someone like u helped me
I am going to reprogram my ESC to 50% mode
and turn down the punch Heck I cant keep it running straight , YET
One question
I know where to hook up the program box to the ESC (Fan Wire)
I hooked the program box to my computer
do I need to hook up a battery to the program box also
along with the Lipo
is this correct
Again
So many thanks
I will buy this type motor again
They delevered it in 3 days
TAZMAX in the dirt again
Got the motor (C2)
Got a Lipo 3S
One question
along with the Lipo
is this correct
Again
So many thanks
#18
Super Moderator
Good, glad things are getting better for you(& I know what you mean about the rain, there's a track in OKC getting ready to open, but they still need to bring in the dirt, & to do so they need to wait for a calm weather window to open up to ship it to the track, figures it'd happen with us getting so much rain, huh?). Now, about the program box, if it's like mine, then you just need a battery plugged into the ESC(& the program box will get its power from the ESC, just like a servo would), & once the battery's plugged in, just plug in the box, then turn on the ESC, & the box should power up too(then you'd hit either the Return/Item or the OK button to start the data connection to the ESC), & when using its PC connection software, do it the same, but also connect the Micro USB cable to the box, then the box to the ESC & then the battery & power it up like before(& I believe the PC interface will give you access to everything from there. Oh, & if you want to soften its acceleration(or make it punchier), you can do either from the Throttle Punch menu, just tailor it to your comfort level(when I'm racing in a spec class, I'll tend to max out the punch setting, but for mod motors I'll keep it in the middle of the adjustment range at first, then adjust if needed). Also, if you get confused along the way, there are also some YouTube videos that can help see what to do(that's how I picked it up, just go there & do a search for things like "Programming a Hobbywing ESC" & you should find some good tutorials, they definitely helped me get used to it)....
#19
How to Clean Motor
Ok I have run my truck 5 - 10 times
After each run I wait till motor cools off and then I wash off all the grass and mud , max temp so far has been 132
how or do I keep motor from rusting ????
should I add a drop of oil to the bearing under the pinion gear
Program box works great Yea You tube
and I got a 2S battery and now I am getting somewhere
charged the 3s on "Store " mode and set it aside
thanks for the help
thanks for the help
#20
Super Moderator
As long as you make sure it fully dries, you shouldn't have too much trouble with rust, but to be safe, there are a couple of items that can help. One is what we refer to as motor spray(like this one: http://gshobby.com/content/duratrax-...y-cleaner-12oz ), that does a good job of removing dirt from electronic components without leaving residue, & some light bearing oil(like this: http://gshobby.com/node/226180 )for the bearings should keep them lubed & free from corrosion....
#21
Best SCT 2WD 1/10
Grizzbob
Just a note
New motor is a beast, I just ordered another one
just to have another one for what ever I buy next
Anyone
what is the best SCT 2WD 1/10
I want to start racing
Thanks ALL
Just a note
Anyone
Thanks ALL
