motor springs
Trinity hard brush springs are a good choice. The Horsepower stock comes with Trinity Red springs on the (+) pole, and Green springs on the (-) pole. I believe Trinity has replaced the Red Springs with Purple ones in their parts catalouge, but I am not sure.
Which springs came on it depends on which one you bought. If you got the tuned version, then Platinum is right. If you bought the "raw" version-which is what I do-then it has grayish-black springs, which are a little hard. A good place to start is with a heavier-relatively-on the negative, and a softer-relatively-on the positive. Reason for this is electron flow. In DC current, electrons reportedly flow from negative to positive. A heavier spring on the negative helps the conductivity, and the lighter one on the positive is just for a "pickup". Don't go to extreme with the springs, one graduation should be sufficient-like heavy on the negative, and medium-heavy on the positive. Your goal should be to relieve as much unnecessary pressure on the comm as possible, without losing power.
Application has a lot to do with it too. Heavier springs result in more torque, lighter result in more RPM. A mixture of the two will have varying results, depending on what you do. For a touring car, lighter is better. For a monster truck, heavier is better.
As always, experimenting is key.
In certain cases the heaviest spring is not always best. There will come a point where more load on the comm will just increase comm and brush wear. This is the point where you are no longer increasing torque, just brush pressure. It takes a lot of pressure, but it is easy to overdo if your experimenting.
Originally Posted by R/C Anonymous
that's funny i've had it wrong all these years
