spare parts
spare parts
Looking to get into 1/10 2wd buggy racing, I was wonder which spares you guys would recommend purchasing with a new kit. I've been reading through threads and it seems like arms, turnbuckles, and ball stud caps are all on that list. Any small things that a newbie to racing would be forgetting to add to the cart?
R/C Tech Elite Member
Looking to get into 1/10 2wd buggy racing, and I was wondering which spares you guys would recomend picking up? Ive been reading through threads and it seems like arms, hubs, and ball stud caps are a must. But i know theres gotta be some other stuff Im not thinking of.
Maybe it's just me, but I always keep an diff rebuild kit, diff gears, & diff lube.
I have a B5. I just raced indoor all winter, didn't break anything all year and on the last race broke a rear hub and wing. Ordered two hubs and a new wing yesterday. Not bad considering I hit the timing loop near full speed about 4 times and hit the wall quite a few more times. My guess ? Get some arms front and back and turnbuckles. That should hold you
It may sound crazy but when you break it sucks if you have to go home because no parts available.
Thanks guys, I appreciate the input! Would've hated for my first race experience to get cut short by not being properly stocked.
Gears, arms, knuckle/uprights for sure.
A arm pins. E clips not sure what rc you have . complete front end parts from bulkhead to axle n nuts.. you can use a cow pusher till you get the hang of it..(bumper RPM)shock caps.c hubs caster blocks.
Since the LHS do not carry TLR parts, I have a complete screw set, 6 slipper pads, 2 spur gears, various pinions, 4 motors, A-arms front and rear, hubs, compete set of bearings, shock towers, shock shafts, shock rebuild kits (2), diff rebuild kit (2), a complete turnbuckle set, ball cups, wings, servos, ESC, tranny case, and more. I can almost build a second car only need the chassis. When I buy the -2.5 I will have a complete car!
