RC Racing Beginners Guide
Anybody know of resources for new racers to learn... not so much about the car itself but I'm really interested in how to actually drive the car?
Thanks in advance
Thanks in advance
Some fundamentals/tips via Tamiya: http://www.tamiyausa.com/articles/fe...article-id=206
There's really no substitute for just driving, driving and driving some more though. It is truly a learn by doing skill.
Went to my track today and put in 500+ laps. No substitute for practice.
That said, there are some good threads on this forum that discuss how to better your driving skills. Use the search function and read through them. Sometimes one thread links to another good one.
Get your car to handle as best as you can, then practice, practice, practice. At some point you may think to adjust something else to help tighten up your lines or gain more speed through a section you're struggling with... try it and practice more.
Timing and reflexes can't be explained in a text. You just have to run the car until you finally get that "AH HA!" moment. When you do, everything will change for the better.
From there it's a matter of practicing until your motor skills become second nature or sub-conscious. Try to diversify the tracks you practice on, driving one track only can hinder your progress in the long run. Goal at the start is keep it on the black stuff and let others pass cleanly. Good driver will let you get to a corner before they make their move, so don't get anxious and enjoy the drive.
Consistency outweighs speed every time, when the best in the world race, they are not only fast but often within .1 second in their laptimes. If you have somewhere to be timed and if there are consistency/deviation/cons on the result, keep a close eye on them. In a five minute session it is often said anything under 1 second deviation means you can do with more car performance.
Thanks so much for the responses that helps me a lot.
This is from a thread a started years ago about this subject. There's a lot of good information here.
http://www.rctech.net/forum/electric...onsistent.html
The most important person you can find at the local track is one who is willing
to help coach the driving line and car setup
My only input for getting better at racing is to start out with the correct tires for the track that you are running at. Any little tweaks to suspension, with the incorrect tires, is just a waste of time. After finding the right tires, start practicing with the kits' basic set-up that is found in the manual, and go from there.
I have been running a lot of VRC pro lately. It isn't the same as actual track time but it is about the next best thing I think.
Advice from a fellow rookie
Some things that really helped me a lot with my car setup and driving:
My track owner (and members of his team) put on setup clinics every month or so. These are unbelievably helpful for rookies. They looked over my buggy, gave me setup suggestions, and troubleshooted issues with me. Even took us out on the track and showed us how to determine lines, had a team member demonstrate the lines with a car while explaining what was going on, etc.
Talk to other drivers with same car during practice and club races. It is amazing how helpful other drivers are in this hobby. I had a list of setup tips in less than 15 minutes. Bring a pen and paper to keep track of them.
Let someone more experienced drive your car. I know everyone drives differently, but I had a fast kyosho kid that asked to drive my B5M buggy at practice. He was getting about the same lap times between his and mine...that tells me I got the setup dialed for the track. On a side note my track has spec tires, so that eliminated a huge pain point from the start.
Practice, Practice, Practice. I try to go at least once a week and run as many batteries as possible. I watch what the other drivers are doing for lines and just try to copy them. If I cant get it, I will just plain ask them what I am doing wrong.
Hope this helps!
Hope this helps!
Advice from a fellow rookie pt2
As I read through the becoming consistent thread (linked in earlier post) I realized one other thing.
I used to struggle on a section in the middle of the track. It was an almost 180 degree turn into a single and table top jump section. I would always end up jumping off the track. So I moved to a position on the drivers stand where I had a better vantage point of that section. Then i realized i was over steering the corner. At this point i realized that other sections that were previously easy for me became a little more difficult because i was viewing those sections from a different angle.
Now i try to practice at various places on the drivers stand. If there is a section I am struggling with then i move to get a better view of that section until i get the muscle memory for that section.
That's a good idea to move around on the stand to learn all viewing angles.
When I use to race long time ago, I did that too during warm up laps to get a sense of the track.
Also, I seem to be far more consistent when I stand on the far left side of the stand than I do standing on the right side. I am starting to wonder if this is vision related. I am left eye dominant and wonder if that makes it easier to track the car when it is to my right.
Wikipedia has a great article on the 'racing line' aka the optimum way to take a corner:
https://en.wikipedia.org/wiki/Racing_line
