single stick radio for stampede
How difficult would it be to program/wire a single stick radio like a hitec focus ss to a traxxas stampede 4x4? I would like to use a single stick because I am a quadriplegic and have no finger function. Any advice would be appreciated.
I don't think that it would be difficult, it should be no problem to just use up/down for throttle/rev and left/right for steering, similar to an aircraft radio where the left stick (mode2) up/down is throttle and side/side is rudder, so in theory you'd just plug throttle into the channel controlling up/down and steering servo into the channel controlling left/right. I don't see why it wouldn't be possible to do this with any 2-stick radio and just use the left stick. you would need to calibrate the throttle stick so that middle stick is neutral though.
