Upgrade a T4.2RS RTR to the kits specs for racing
#16
Before out go buying a new motor and esc, put a smaller pinion gear in it. That should cool down you motor temps. After you run for about 3 minutes, if the motor is still too hot to touch you gearing is too low...keep going smaller on the pinion until the temp is under control....160*f is about the hottest you want the motor to get. Fix what you have don't be so quick to buy new stuff unless you really want it...
Good Idea. I will give it a try and see what happens. When (if ever) should I look at changing the spur gear?
I did already order the new stuff. I kind of want to replace all the stock AE stuff and get what I want in there. But I have a fleet of cars and trucks so I can always find something to put the motor in.. hehehe
#17
you usually only need to change the spur when you run out of room whit a large pinion or when you don't have gear mesh when you go with a smaller pinion.
#18
at least you have a back up motor now...
#19
Yes Spare parts is a good thing.
I prob jumped the Gun on the motor and ESC but I am trying to complete a five race series. Last Friday I could not even finish a heat with the problems I was having. At least I can throw out my worst race in the series , cuz it was definitely last week.
#20
I'll probably try to start racing in the summer, did some 19.3's Tuesday in the last layout, I'm thinking that should make me competitive in Rookie???
#21
I guess that they changed the track again. I was trying to run the Friday series but will not be able to make it tonight or next Friday so I am out..
Got the new motor coming in today and I am hoping to be able to get back out to the track and see how well it works.
Hopefully I will see you there.
Tony..
#22
Sweet ! That is a damn good time for Rookie. I cannot even get past 20's.
Tony..
Tony..
I just built a 22 SCT 2.0 and will be out there next Tuesday at lunch trying it out.
#23
What tires do you have on the truck?
#24
I talked to folks at the track and I ended up getting the Jconcept Webs all around.. Their nice but are taking forever to break in.. I would suggest some parking lot runs if you go this route to break them in... Lots of people are using liquid wrench as a "sauce". I tried some but because I broke every race I really could not see how well it worked.. But the fast guys swear by it so it must work.
Wish I coul head out on Tuesday but I have work and then baseball. Very interested to see what changes they did with the track..
#25
Regional Moderator
I talked to folks at the track and I ended up getting the Jconcept Webs all around.. Their nice but are taking forever to break in.. I would suggest some parking or runs if you go this route to break them in... Lots of people are using liquid wrench as a "sauce". I tried some but because I broke every race I really could not see how well it worked.. But the fast guys swear by it so it must work.
#26
They are working great as they break in. But are it so good when it's wet.. This could be because they are not fully broken in yet, but I am not sure..
#27
#28
Cool, I bought a set of dirt webs for the 22 SCT 2.0 I just finished building, so we'll see how that goes.
I've also tried AKA soft wishbones (SC), HB beams/full slot pink (buggy), and handlebars (SC).
Whatever you do, don't get Proline MC compound, I had some suburbs SC tires and they do not stick at all at the track.
