I think my battery is dead.
HI everyone.
I have a Losi 1/24 scale truck. I have the 3s 11.1V 200Mah 15c Lipo battery. Over the weekend my son was driving the car with his friend. After they were done he brought the car back in, turned off the transmitter, and forgot to turn off the truck. It sat on the table for a couple of hour before I noticed it was still turned on. Battery was dead, nada, nothing.
Tried to charge it with my H1 and it says "warning low voltage" and will not charge it. Did the battery get ruined because it was discharged to much ?
Then I tried to use the cheap wall charger that came with the truck. Plugged it in for a couple of hours, still dead. I even tried the H1 again hoping that the wall charger would have put some life back in to it, nope....
I thought that I read a thread somewhere saying that you could "jump start " a Lipo battery by using the Nicad or Nimh setting on your charger. I believe the thread said to only do this for a couple of minutes only due to fire concerns.
Just wondering if something like this is even possible ?
Has anyone ever heard of doing this to try and save a Lipo ?
Thanks in advance!
Thanks in advance!
I was a bit discouraged at the price I found on these Losi batteries from Amazon, $46 with a wall charger.. I have been looking around and have not found cheaper stuff.
Where would you guys suggest to look for a battery ?
I've "bump started" a few lipos, no problem. Like above, change your charger to NiMi setting. But just charge for 15-20 seconds and then try charging it normally. If it still shows "low voltage" then yeah, toss it.
I believe this is actually the updated version of the battery for that: http://www.tlracing.com/Products/Def...rodID=DYNB0002
under $26 shipped to my door..
Thanks so much for the link and info..
if it ever happens again (and it will, with kids and RCs), do like mentioned above, with charging on NIMH setting briefly. Here is one tip that I do, pick up a lipo alarm. Plug the battery into it, and watch the voltage come up slowly while you charge on NIMH. Once all cells are above 3.0v, quickly unhook, and go back to balance charging like you normally would. Keep in mind, if the cells are drained way down (under 2v) it is more dangerous and perhaps a lost cause to try to save it. I've revived many batteries, but it certainly isn't good for the battery, nor is it a best practice!
I've successfully "jump=started" many a LiPo pack. It really only usually takes about a minute on a NiMh setting to get it to register enough to charge in LiPo mode. It's sending power to your battery either way, it just would not cut off if it was in NiMh mode so you couldn't just fire it up and walk away, but other than that there is no problem in doing it.
Makes me feel good to knows others have done this many times before..
On a side note your not to far from me. I am over in Santa Cruz. Have you been to NorCal's track ? I have been going there with my kids and we are having fun...
Ha! It totally worked !
Charged it in NiMh mode for about 25 seconds until I felt the pack start to get warm.. Switched it over to Lipo mode and it started to take a charge! So stoked it worked and I did not blow myself up
Thanks everyone for the advise !
Worrisome thread, full of disinfo. Bumping a battery is not recomended, due to chemical changes thast occur in the chemistry of the battery, when it's discharged too far.
...The entire process of building up that lithium oxide usually takes around 300-400 charge/discharge cycles to reach a tipping point. That's a typical lifetime of a LiPo battery. But when we heat the batteries up during a run, or discharge them lower than 3.0 volts per cell, or physically damage them in any way, or allow water to enter the batteries (and I mean inside the foil wrapping), it reduces the life of the battery, and hastens the build up of Li2O....< puffing<
http://www.rogershobbycenter.com/lipoguide/
I don't what's worse, advocating bumping or claiming it's all good, especially from a battery retailer per sig. In short, the battery will probably never be the same, the life will probably be shorter, the internal restance most certainly went up, at least on the severlly depleted cell, eqauting into higher battery heat upon discharge. Severe out of balance voltage upon recharging, could indicate different cell resistance.
I won't even get into the crystal changes that occur in the chemical, when discharged too far.
Boss, imo and per many manufactors, just buy you another battery and replace that one, when the new one comes in.
