ESC/Motor Guide, Formula?
I've been around RC for many year but have only recently gotten back into electric stuff. What I'm wondering is, is there some sort of rule of thumb, formula or chart for knowing what ESC to run with what motor or what motor you can run with what ESC? This brushless stuff is tough to grasp. I don't want to buy some monster ESC if I don't really need it for the motor I'm running.
Thanks for any help that can be offered.
Though as a generalization...
Typically escs will fall into 3 categories
Ones for 1/10 2wd buggies/ trucks and 4wd buggies. These are typically 50-200 amps and come in smaller cases with optional fans. They typically have a turn limit as well, so a tekin rs has a 8.5 limit meaning motors faster than an 8.5 are too much for the esc to handle.
Ones for 1/10 4x4 sct. These are typically 80-250 amps and come in larger cases, often with built in fans.
Ones for 1/8 buggies/truggies/scts. These are typically the largest, and are usually 200+ amps. However, it is popular to use one in 4x4 sct.
Motors typically come in 540, 550 and 1/8 cans. There are exceptions, but these 3 are the standard. For 2wd buggies/trucks and 4wd buggies you use a 5402pole motor. In 4x4 sct you use a 540 or 550 4pole or a 550 2 pole, this isn't as popular now. In 1/8 can sizes there are buggy size cans and truggy size cans, truggy ones Being longer. On 4s kv is usually 1800-2200 kv.
Thanks for that info. What exactly is 2 pole, 4 pole etc? I see it and hear it a lot but what exactly does it all mean?
And do you gain anything by going with a bigger amperage ESC than the motor really requires?
2-pole motor =2 electromagnets(1 north and 1 south) ---More RPM
4-pole motor = 4 electromagnets ( 2 north and 2 south) --- More torque
Most people run ESCs that are WAY too powerful for their motor. The only thing you gain is that an ESC that's overpowered will run cooler with a smaller motor. I would recommend that you don't buy more than you need unless you really just like spending money and having new toys (which is a large part of this hobby, honestly).
Thanks, guys, that info was very helpful. It answered most of the questions I had about upgrading my motor and ESC.
Have a Blessed Day,
joe1950
Have a Blessed Day,
joe1950
