battery help needed
#16
1800 and 2100 refer to cell capacity,
thanks for the battery info ................. steve
#17
i cant seem to find a lipo that is thin enough to fit in my car . my battery pack is only 1" thick . the ones ive seen are 1.7 / 1.8 . they will be on the ground ........ thanks .. steve
#18
Try Turnigy Nanotechs. They are pretty thin but long. I would take measurements of your battery tray though to be more accurate. Most sites will give you the dimensions of the battery so you can get an idea.
Side note...lol you don't have to say, "thanks Steve," all the time. We know it's you. It's not a big deal I just feel like I'm reading an email or something Lol. Please take no offense to that I'm just one of those people who notice little things like that.
Keep the questions coming though man. We're here to help.
#19
being a newbie on top of an old guy , just the way i was brought up . just greatfull for the help & info ...............
#20
ok , do you think this will work for my car ?
Capacity(mAh) 3300
Config (s) 3
Discharge (c) 25
Weight (g) 263
Max Charge Rate (C) 5
Length-A(mm) 146
Height-B(mm) 43
Width-C(mm) 20
mine now is a ni-cad nun2100-csf hyy-10 ...............
Capacity(mAh) 3300
Config (s) 3
Discharge (c) 25
Weight (g) 263
Length-A(mm) 146
Height-B(mm) 43
Width-C(mm) 20
#21
Did you measure the battery tray? I'm not all too familiar with 1/4 Indy, but that could answer your dimension question on whether it will fit or not. A 3s 3300maH 25c is fine dependent on what you are doing. Racing, I don't think a 25c is enough for a 1/4. I would look for at least 40c. Now just for my own interest is your car all electric or gas powered with a receiver battery I it?
#23
my problem is most of the batteries are to tall . your idea is good . ill work on that . my car is all electric . my box is ... 6 1/4 x 3 1/2 x 1"
long .....wide high
long .....wide high
#24
ok, what I was thinking of would be too big then. It would be roughly 7 3/4"L x 3.9"W x 3/4"H
Maybe two of these new block style batteries could work. If you put them side by side they would be 5.4"L x 3.6"W x 1"H. Might need to modify the battery compartment, if that is possible, to accommodate the wiring as well.
#25
thanks . ill check them out
#26
Seems like a small pack for a 4 foot long 1/4 scale car. Granted I'm sure the Indy body limits packaging space. Any idea how much it weighs? Any info on the motor and speed control?
#27
i dont know the weight or motor specs . ill try to get them .........
