i need information
http://www.usvintagetransam.com/rules/index.html
It does say what the chassis requirements are. "Any 1/10 4wd or FWD sedan with 4 wheel independent suspension." For example, any of these are valid: http://www.amain.com/index.php/cPath...uring-Car-Kits
Motor is any ROAR-approved 21.5 turn motor with the stock rotor installed. Start here: http://www.roarracing.com/?page_id=251 Press CTRL-F (or whatever your browser's search key is) on that page and search for "21.5". Use any of those listed.
USGT Class Rules and Specifications
Note: JANUARY 1 2014 The Ride spec tire will become the official spec tire for USGT
RIE24025 - set of 4 available through Gravity RC http://www.teamgravityrc.com/ to dealers and retail
Chassis Specification:
Any 1/10 4wd or Fwd sedan with 4 wheel independent suspension.
Weight Specification:
4wd 1450g weight Fwd 1200g weight
Body Specifications:
Any 190mm or 200mm body. Body can be any body that is NOT on the ROAR T2 body list. FWD encouraged to use FWD bodies However, Can AM or IMSA style bodies, similar to 1/12 or 1/8 bodies are also discouraged NO Trucks
Any "SCALE" molded wings can be used. Lexan wings 10mm maximum height / side dam height
Scale type race liveries encouraged
Tire & Wheel Specifications:
Tires- RIE24025 - set of 4 available through Gravity RC http://www.teamgravityrc.com/ to dealers and retail
Grinding of tire tread is NOT permitted. Sanding of mold seam to remove seam is allowed
Wheels- Any 24 or 26mm spoke (non-dish) type wheel
Ride Height Specification:
Minimum ride height is 5mm.
Motor Specifications:
ROAR approved 21.5 + 2s lipo batteries No tuning rotors, must use OEM rotor 12.3-12.5mm
Approved ESCs:
ESC ROAR approved spec software or USVTA list
Race Specification:
6 minute qualifiers
8 minute mains
Battery Specifications:
ROAR approved hard case batteries
took one google search.
Approved ESCs:
Race Specification:
6 minute qualifiers
8 minute mains
I think you should head on down to the track you're planning on running and see what classes they have and see what equipment everyone is running.
The only options i have right now in the ESC is
1 Speed Passion Reventon Stock Club
2 NOVAK Club Spec Sensored Brushless
3 Hobbywing XERUN 120A Brushless
In motors
1 MUCH MORE FLETA ZX 21.5T
2 LRP VECTOR X20 Brushless Competition Motor Stock Spec - 21.5
3 Trinity Killshot 21.5T
In motors
