Straighting bent chassis. where to post
Hi all, i was looking were post a question about info on staighting a bent chassis on a ofna hyper 9e.
I will order one but as it happened on my first day of ownership i would like to get it going while i wait for the new one.
thanks for any help
sydney aust.
thanks for any help
sydney aust.
Another way is to use a large enough vise, with some soft wood blocks. Will need to over bend some as there will be some spring back. A hydraulic shop press works well if you have access to one (or so I've heard ).
The mallet technique would probably also benefit from a large soft wood block to support the chassis as you work on it. Something with a little give.
Regardless, the most important ingredient is patience. Go a little at a time, avoid the overdo it temptation.
