Nylon pops out of nyloc hex nuts when installing - Solution?
I have Assoc. extenders and Assoc. nyloc hex nuts. All blue matching parts.
When I thread a nut on, it just pushes the nylon out of the nut.
Out of 4, 1 went on properly and 1 ruined the nylon ring.
What's the trick?
Tried spray lube and grease but no help there.
What's the trick?
You really don't want to lubing any threads even though you're putting on a nyloc nut over them. Sounds most likely like a possibly bad nut or two. I'd use what you have and then maybe try a different brand. Using the 3mm size as an example, I've found these to have significantly less issues (as in none) with poorly machined threads, etc. than these, YMMV.
