Steps to setup my car
Hi! I'm almost done with the building of my first car. Its a Tamiya TA06pro.
Thinking ahead. I'm wondering which is the first thing to set? Droop? Ride height? Steering?
I came out with a list of steps for setting up. Please correct me if I'm wrong. (Steps are in sequence)
1) Droop
2) Steering - With the servo arm 90degree, adjust the steering turn buckle so that the car is going straight (not using trim).
3)Toe
4) Camber
5) Ride height - I intend to do it last as I think camber adjustment will affect ride height.
1) Droop
3)Toe
4) Camber
Out of the 5 things you've listed, Hudy/Xray suggests:
Ride height
Droop
Camber
Toe
Steering
Hudy's setup book can be found here (Zip file): http://www.hudy.net/xhudy/showfile.p...252739b1ad8c24
Ride height
Droop
Camber
Toe
Steering
Ride height
Droop
Camber
Toe
Steering
Ride height
Droop
Camber
Toe
Steering
