Go Back  R/C Tech Forums > General Forums > Rookie Zone
SC10 4x4 diff ???? >
SC10 4x4 diff ????
SC10 4x4 diff ????
Old 06-02-2013, 04:07 PM
Trader Rating: 62 (100%+)
Default SC10 4x4 diff ????
I have a SC104x4 i am the only owner off this vehicle. I have been getting some clicking noise at the rear on left turns with throttle and at full throttle from start. took trans apart and it looked good. I heard about these having problems with diff.....could this be my problem? I only had this truck for 2 months!
wileycat is offline
Old 06-02-2013, 05:02 PM
Trader Rating: 30 (100%+)
Sounds like your rear gearbox pinion and diff gear aren't meshing properly. You need to shim your rear diff to make this tighter. Replace anything that looks bad.
sdtech58 is offline
Old 06-10-2013, 11:40 AM
rjohn929's Avatar
In case you haven't fixed this yet, it sounds like you need to update the shims in your differential. All the info you need is in the SC10 4x4 thread.
rjohn929 is offline
