Battery directly to Brushed motor
Is it possible to hook a HPI Racing 1146 Firebolt 15t Motor (540 Type) directly to a battery without an esc? I just want to be able to turn it on and off. What kind of battery would you recommend?
So a 7.2v Ni-MH battery would be too powerful?
Hooking up a Battery directly to Brushed motor
Is it possible to hook a HPI Racing 1146 Firebolt 15t Motor (540 Type) directly to a 7.2 Ni-MH battery without an esc? I just want to be able to turn it on and off.
Yes it's possible. positive to positive, negative to negative. Wire in a switch on the negative side. Good luck controlling it.
Ok. Thank you.
Will it burn up if it runs for 2-3 mins?
I'm only using it for about 2-3 minute runs a total of 4 times. With enough ventilation, would the motor and battery be alright? Do I have to run the battery down to zero after every 2-3 min run even if all 4 runs will be in one day?
