Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 01-27-2013, 08:58 AM   #1
Default What's the difference between a 540 and 550 motor?
I plan to race a stock 17.5 motor but I keep reading about these 2 different sizes. Which do I select?
Join the Inland Empire R/C Truck & Buggy Club @ http://www.facebook.com/groups/211362002333733/
Running 22sct, D3.5 17.5, Tekin RS, MX-V, and at least 6500mAh/60c in the I.E.
johnmo is offline   Reply With Quote
Old 01-27-2013, 09:36 AM   #2
SolderGlob's Avatar
a 540 and 550 are the same diameter, the 550 has a longer can.
Selecting between a 550 and 540 really depends on the vehicle you're going to be using it in. Some will only accept a 540.
Losi Nitro SCT···Losi 3-shoe clutch···125 cc tank mod···Savox 1267(st)···Savox 1257(th)
Losi 810e···CC 1415···MMP···3s LiPo···Savox 1268
SolderGlob is offline   Reply With Quote
Old 01-27-2013, 09:46 AM   #3
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 152 (100%+)
540 sized motors are more for 1/10 scale buggy / truck...stuff like that. The 550 motor is meant for the larger/heavier stuff like the 4x4 short course stuff. If you are planning on 17.5 racing your only choice is the 540.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 01-28-2013, 09:25 AM   #4
cdwilliams1's Avatar
Trader Rating: 38 (100%+)
550 can also have a longer shaft where you attach the pinion. In some cases, it will not fit inside the plastic gear cover (like on 1/10 buggies for example).
I race at www.mncarpetoval.com !
cdwilliams1 is offline   Reply With Quote
T.R.C.R. ---Pit's Talk--- teambighead Northwest Racers 25138 05-14-2017 12:49 AM
EPMTs check in here. (a subsidiary of TNT) overtki11 Singapore R/C Racers 55470 05-07-2017 11:57 PM
Viper RC - mini-dub Radio and Electronics 12063 03-06-2017 08:33 PM
Novak 550's Roar approved Failedabortion Electric Off-Road 81 04-06-2011 10:18 AM
Motor/ESC.......What's the real difference? hnasdad Radio and Electronics 10 12-17-2010 04:35 AM
