Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 10-08-2012, 10:55 PM   #1
Airmanudota's Avatar
Default Pull start loose "slipping"
More problems ...
When i crank my pull start its almost loose .... im able to start the engine but it was a lot harder to pull before , sometime when i pull i feel the piston is not moving at all ..... once it started engine seems to run well this all stared when i finished my gallon of fuel ( o'donnell 20%) and now using blue thunder sport 20% maybe just a coincidence i dont know
Im new to RC cars ... but really addicted , i have a 777 kyosho with star K4.6 nitro engine
Airmanudota is offline   Reply With Quote
Old 10-09-2012, 01:58 AM   #2
blis's Avatar
Originally Posted by Airmanudota View Post
More problems ...
It's a one way bearing in a hex nut. Basically a roller bearing cam, and I suggest you remove the engine, and then remove the scews/bolts that attach the the pullstart.
Then clean the one way bearing with WD40 and then put a clean rag throught it and turn to really clean the roller bearings. We use a special "one way" lube, it's a very thin but not OILY lube and unless u can get some, the WD40 and then cleaning off the residue should do the trick.
While you are at it, clean the shaft that connects to the engine's crank and if you are really keen, you could remove you clutch and give your engine a good clean too.
I would also take the opportunity to clean the engine's outer with a degreaser, just be sure to block off the air intake and fuel nipple.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 10-09-2012, 02:35 AM   #3
Ill give a try and let you know sorry to ask how do i clean the engine once i remove the clutch ?
Thanks again Bliss
Tags
pull start slipping
