upper deck?
Suspended
Location: please try not to look at my avatar to long may cause u know what
upper deck?
im not a newb but thought this would be the best place to post. i have a rush evo and the cabon upper deck was 70 $ [hahahahaNO] so i made my own out of plexyglass. it is 2.5 MM. its thick stuff.i dont know if that will hold .i was thinking of coating it with a fiber glass coating to make it more durabel does any body think that it neeeds to be coated with fiber glass.i will be bashing and racing if that helps
Suspended
come own does any body know
Suspended
i need more room on top
its plexi glass, I dont think it needs to be stronger. Plus, it must be pretty heavy.
A few problems to consider. Plexi doesn't like nitro fuel - it'll look awful pretty quick, and there's a good chance that a reaction between the nitro and the plexi could weaken the upper deck. And I'm not convinced the plexiglass upper deck would be as strong as the factory deck. How do you plan to beef up the holes that the screws will pass through? The screws may bust the plexiglass the first time you drive the truck. Plexi was never meant prevent torsional flex, your chassis will probably have a bit more flex, too.
Suspended
the scres arnt corese threaed into the upper deck i nut and bolted them down to it and used washers. and nitroracer20 to answer ur question it is lighter
Suspended
o and its not frbers for the fiber glass it is cloth
So, what was the point of posting your question? You've already got your mind made up. I've been in the hobby for over 20 years - I tried going down this road when I was a kid, it never worked. Ask yourself - Why do I never see plexiglass parts on r/c cars? I'm trying to save you from wasting your time, and possibly embarassing yourself out at the track when the upper deck snaps and you taco your chassis.
Why do you need more room? Modern electronics should fit within the areas that HPI designed to contain them.
I doubt the plexi glass upper deck is lighter than the cf one.
Suspended
ya i guse ur right i am getting one made by a frind out of a meatle its light waight and very strong so it will solv all my broblems. there isnt enough room on the deck because once u get a reciver protector it dosnt fit in the campartment where hpi puts it then i got a fail safe by ofna and a 5 cell rciver back an the upper deck has a curv on it so its a bitch to mount stuff to
I have the ofna micro failsafe and I just use double sided take to hold it to my reciever box. Works fine
Later
Later
Suspended
ya im in canada and it snow rain and crap like that all the time so i like to have my stuff water tight
