Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 03-05-2005, 09:50 AM   #1
Default Battery re-matching
how often do you guys tear down your racing packs and re-match them? the reason im asking is when my batteries were new (3300 ni-mh MATCHED) the ran great.. now that they have about 15-20 runs on them, they are so flat!! i charge at 5 amps discharge at 30amps to 3.6volts (4 cell) then store till next week..before charge i tray till .9volt per cell then charge.... never had dead shorted them... i took one pack apart and ran each cell through a cycle on my turbo 35 and the numbers when crap.. they were 400+ sec 1.170+ when new. now they are 220 ish at .999????? so what do you guys think? and to top it all off they are only 1 season old.... HELP
CORALLY NUT is offline   Reply With Quote
Old 03-05-2005, 09:48 PM   #2
Suspended
Trader Rating: 14 (100%+)
Well, are you overcharging, undercharging, overheating, overcooling, or just plain abusing them? If you're traying them properly, charging properly, and discharging properly then they should be fine. What matcher are they from? Are the batts worth a crap to begin with? I've never had to rematch a pack, and I abuse my cells quite nicely, but I run quality packs.
Matt
Phatkat is offline   Reply With Quote
Old 03-07-2005, 03:36 AM   #3
Cole Trickle's Avatar
I'm using GP3300, and they still produce very good numbers after 11 months and approx 30 runs. I'm using fukuyama cells, and I also follow their guidelines, except, I keep the temperatures lower, that is 50-55 degrees celsius.
So I would also say there's either something wrong with yours packs to begin with, or the use and care.
Explain more detailed what you do, maybe we can assist you.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Battery matching Mike01 Electric On-Road 0 02-15-2005 07:08 PM
Battery Matching killerjvf Electric On-Road 7 01-31-2005 09:32 PM
Battery Matching killerjvf R/C Items: For Sale/Trade 2 01-31-2005 02:42 PM
battery matching HK Racing Joe Electric On-Road 1 10-31-2004 07:15 PM
battery matching gspot69d Electric On-Road 9 10-13-2004 03:26 PM
