Lipo Charging?
If you see 8.45 volts or more, and are still charging at 6amps... you might have an issue. But 8.40 isn't fully charged yet.
Charging
Most chargers will only allow the voltage to get to 8.4v for a 2c lipo when charging in lipo mode. Some chargers however, do allow the voltage to go slightly higher. The amperage will slowly decrease after the max voltage is reached. If your charger isn't doing this, then there is something wrong.
