Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 07-17-2012, 02:22 AM   #1
gelshocker's Avatar
Default Problem with throttle going on by itself during steering, 2wd buggy
I have a problem that's developed with the throttle going on by itself (twitching), whenever I apply steering alone. It's a 2wd buggy. Anyone know where I should start looking? Thanks,
RB5
hobbywing xerun v2.1
savox 1258TG
Sanwa MT4 tx/rx
Kyosho RT5 | RB6
gelshocker is offline   Reply With Quote
Old 07-17-2012, 03:47 AM   #2
justpoet's Avatar
Trader Rating: 16 (100%+)
There are several possibilities, but I'll suggest the easiest to accidentally end up with first, as it will also be the easiest to fix. It sounds kinda like you have some form of channel mix going on with your radio. Check to see if there's a setting for it, and make sure it is off.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 07-17-2012, 03:57 AM   #3
blis's Avatar
RB5
savox 1258TG
Sanwa MT4 tx/rx
A wild guess would be either your steering is sticky and causing load on steering servo or, servo is on it's way out. Could also be a receiver capacitor failing.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 07-18-2012, 10:39 AM   #4
chucko's Avatar
servo might be drawing to much energy. a 10 dollar cap might help in the receiver. also make sure your end points are set so no binding in steering. if it binds it draws to much and starts affecting other things like throttle and acc side and you might miss a lap or two because of the over power drain.
Losi 22, XXX, SCTE 2.0, 8ight E.2.0, B44 and last but not the last a 44 .3, M11 X
rc scoring pro
Track owner & race director.
Crook County Race Course Prineville Oregon.
chucko is offline   Reply With Quote
Tune With Camber Links Sarinexia Electric Off-Road 2141 10-18-2016 05:32 AM
