Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 07-12-2012, 03:20 PM   #1
Default Removing solder from ESC
It took me a while to get the hang of soldering. Now I have the opposite problem. I need to remove the wires from my Tekin RX8 and put new ones on. Does anyone have any specific tricks to make this easier?
I was just going to heat up the solder and see if I can tap it on the bench to get the solder to roll off.
Or, are the posts on the RX8 replaceable?
Any help is much appreciated.
Losi SCTE.
Future 1/8 buggy/truggy???
newbrc is offline   Reply With Quote
Old 07-12-2012, 04:24 PM   #2
justpoet's Avatar
Trader Rating: 16 (100%+)
Don't worry about getting all the solder off.
Heat the wire side while the rx8 is held down (rubber vice, servo tape to workbench, etc). While heating each wire at the joint, use a pair of needle nose pliers (or anything that won't melt really) to gently pull the wire away from the rx8. As soon as the solder liquifies, that gentle pressure will pull the wire off of the posts, along with the heat source, and everything will be perfectly reusable...basically with both sides tinned.
Repeat for each wire.
"We do not act rightly because we have virtue or excellence, but we rather have those because we have acted rightly. We are what we repeatedly do. Excellence, then, is not an act but a habit." -Aristotle
My wallet supports: TeknoRC.com, NorCalHobbies.com, SMC, Tekin, and several tire/servo companies.
justpoet is offline   Reply With Quote
Old 07-12-2012, 04:25 PM   #3
scottmen's Avatar
There is this stuff called solder wick. It works great. You just heat the wick like you are soldering it the post and it just sucks it up.
They sell it at radio shack.
http://www.radioshack.com/product/in...ductId=2062744
Killer Bee Squad Member
scottmen is offline   Reply With Quote
Old 07-12-2012, 04:29 PM   #4
Both awesome recommendations. I will try it first without the wick. If I struggle, I will pick some up tomorrow. Thanks again guys.
Losi SCTE.
Old 07-13-2012, 03:58 AM   #5
blis's Avatar
+1
Goots wicks are handy.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 07-13-2012, 06:06 AM   #6
ironzgti35's Avatar
Trader Rating: 20 (100%+)
What about a solder sucker? not sure if they would work on a large post like the RX8 but they do a great job on small boards. I was going to swap my tekin wires out for Dean wet noodles and figured the solder would just serve as a pre-tin to the new wires
ironzgti35 is offline   Reply With Quote
Old 07-13-2012, 08:32 AM   #7
Super Moderator
racer1812's Avatar
Trader Rating: 31 (100%+)
Master the "heat and flick" method and you won't need any gadgets.
Doing it on the carpet or kitchen table is ill advised though ..
Stand for the flag, kneel for the fallen.
Thank you to all of our service men and women!
racer1812 is offline   Reply With Quote
Old 07-13-2012, 02:21 PM   #8
Jtipsy's Avatar
Stick with the tekin wire for the rx8 the wet noodles dont fit as well as the tekin wire does.
Joseph Tuepker
Jtipsy is offline   Reply With Quote
Old 07-13-2012, 05:07 PM   #9
asc6000's Avatar
Trader Rating: 15 (100%+)
LOL I do the heat and flick and when people see it they are blown away, it's the only way I know...
also to get the solder to flow don't keep adding solder, use a little flux and it will flow like water and "tap" right off.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 07-13-2012, 05:15 PM   #10
Just tried the "heat and flick". All solder is off and new wires are on. Thanks for the help and recommendations.
Losi SCTE.
Old 07-15-2012, 07:20 PM   #11
Airflow's Avatar
Please show me/us how to do the heat and flick method. Better with video.
Want to learn something new.
Airflow is offline   Reply With Quote
Old 07-16-2012, 12:40 PM   #12
I should probably rephrase my previous post. I used MY interpretation of the "heat and flick." Not sure it is too video worthy yet Basically, I heated the solder up until it was in a liquid form, then tapped or "flicked" the speed control and the solder came right off (on to my finger. OUCH) But I got the hang of it by the time I was done with the ESC.
Losi SCTE.
Old 07-18-2012, 09:44 AM   #13
ziggy1013's Avatar
could somebody post a video of this pls.
ziggy1013 is offline   Reply With Quote
Old 07-18-2012, 10:32 AM   #14
chucko's Avatar
most soldering irons when cleaned will suck up a little of whats left on to the iron. just don't let it sit there and cook the speed control. a wet sponge works great. tinning the iron helps make it faster to remove wires.. radio shack has braided wire that sucks it off when used. then I take a small dremel and do a small cleaning with a good grinding tip then re tin. dont be in a hurry. let the speed control cool down for 10 min on each post or it could do damage to the inside and there is a video on elect off road page on how to solder and clean its great .
Losi 22, XXX, SCTE 2.0, 8ight E.2.0, B44 and last but not the last a 44 .3, M11 X
rc scoring pro
Track owner & race director.
Crook County Race Course Prineville Oregon.
chucko is offline   Reply With Quote
Tekin RX8 1/8 Scale Brushless ESC Thread sharkman Electric Off-Road 18835 09-11-2017 07:44 AM
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 05:57 AM
Losi 1/8 8ight E 4wd Thread tyhodge07 Electric Off-Road 8898 11-17-2015 05:31 PM
GTB Speed Spectrum ESC Pete Thomas Electric On-Road 97 11-29-2008 06:35 PM
