Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 02-24-2005, 10:22 AM   #1
Send a message via AIM to Evilpete
Default bulb discharger question
I'm planing on building my own bulb discharger. My question is can i use a wire coat hanger to solder the bulbs on?
Evilpete is offline   Reply With Quote
Old 02-24-2005, 12:14 PM   #2
schmelme's Avatar
yes but you will have to strip the epoxy coating off of the wire where you plan to solder it. Try paint thinner or something similar should do the trick. If not get some wire from the local hobby shop its cheap and works great.
schmelme is offline   Reply With Quote
Old 02-24-2005, 01:13 PM   #3
thanks, instead of using the thinner, could I just sand the wire?
Old 02-25-2005, 01:00 AM   #4
Super Moderator
Grizzbob's Avatar
Yeah, that should work too, as long as you make sure any coatings that might interfere with the connection to the bulbs is gone....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 03-02-2005, 07:20 PM   #5
nwilcox88's Avatar
Are you going to build in a cutoff in your discharger? The reason I say this, going with coat hanger will create resistance.
nwilcox88 is offline   Reply With Quote
bulb discharger minnesh R/C Items: Wanted to Buy 2 10-08-2007 05:45 PM
Pls help with bulb discharger Blackwrench™ Australian Racing 7 09-25-2006 08:56 AM
Bulb Discharger Jimmy Morris Electric On-Road 12 08-23-2005 03:12 AM
wtb bulb discharger fly442 R/C Items: Wanted to Buy 0 12-28-2004 03:57 PM
Bulb discharger MX3 Electric On-Road 6 03-17-2002 04:17 AM
