Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 02-16-2005, 08:28 AM   #1
Ridge_Racer's Avatar
Send a message via MSN to Ridge_Racer Send a message via Yahoo to Ridge_Racer
Default Motor Choice
Hi
I have a Team 1 stock motor in my Tc3. I look on the team1rc web site and it just shows the motor with no stats. Can some one give me some stats on this motor?
Also can that someone recomend some other stock motors? Ones (if possible) that have better tourque or top end speed?
thanks
http://www.countdowntovegas.blogspot.com
Ridge_Racer is offline   Reply With Quote
Old 02-16-2005, 04:28 PM   #2
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
Well i luckly have one of these motors. The motor I have has alot of RPM's. I think that motor is more used for open tracks just my opinion because my car never has the acceleration out of the turns.
Another great all around motor is Putnam. They have the best overall performance and thats one of the only motors ive ever used. It has alot of power, RPM's and touqe without having to much of one over the other.
If I were to get a motor i would get a Putnam. Great motor. What you really want to look for on a motor is one that has good power, efficientcy.(if i left one out sorry). You can have as much RPM's and your motor doesnt have and efficientcy to it and its just a waist for the rpm's.
Motors can be complicated to understand, but with the right knowledge, understanding and if u look at the readings correctly about the motor you can choose out a good motor every time.
I hope this helps. If you need any more help just post here.
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 02-17-2005, 07:43 AM   #3
Thanks for the advice. Dose Putnam have a site I can visit?
Also as far as spur gear choices, with my current motor I only have a few spur gears to choose from without burning out the motor. I am guessing this is true with any motor I buy?
thanks again
Old 02-17-2005, 07:58 AM   #4
howard hudson's Avatar
R/C Tech Charter Subscriber
thanks again
the stock 72 tooth spur should be fine for most tracks. Now a important rule to remember when gearing a motor is the more RPM you have use a smaller pinion . that will give you more punch and make the motor top out sooner, when you have a motor with more torque use a bigger pinion and it will do the oppisite (sp)
you can log onto gearchart.com and print up a gear chart for yourself this chart is very useful when it comes to finding out your final drive when your at the track
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 02-17-2005, 01:44 PM   #5
Putnam does have a site. But they dont have the motor im talking about. http://www.putnampropulsion.com/
ProMatchRacing
Team Corally
Superior Hobbies
novak Xbr esc motor choice CREWMAN Electric On-Road 6 04-16-2008 05:22 PM
Best choice for Motor BKMongoose Electric Off-Road 5 10-04-2007 10:35 AM
4wd off-road motor choice FowLer Electric Off-Road 13 10-10-2006 01:41 AM
High End Motor Choice M.J Electric On-Road 1 06-22-2006 06:48 AM
motor choice and set-up 4 drifting xray racer Electric On-Road 1 03-30-2004 12:47 AM
