Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 05-31-2012, 11:57 AM   #1
Questions?? Differentials in 4wd buggy?
I'm getting a 4wd electric buggy (Himoto Zmoto) and I'm wondering what a good baseline to start experimenting with different weight fluids would be. I;ve seen a few things that refer to thinner or thicker in each differential, but relative to what? Each other? All Three?
brenman is offline   Reply With Quote
Old 05-31-2012, 10:36 PM   #2
Airlmeier4422's Avatar
What up fellow RC racer. Diff fluids can be ranged from 500(VERY thin) to 200,000(VERY thick) and everything in between. Most buggies are usually in the 1,000(again thin) to the 10,000(again thick) range. Each diff doesn't have to be the same and a good starting point is 5,000 in front, 5,000 in center and 3,000 in rear. This will provide a decent balanced setup for multiple track surfaces (dry, wet, tacky).
This next part is directly from the Hudy Setup Guide.....
FRONT
Thinner diff fluid (low number)
-increases steering into corners
-to thin and you can loose front traction (front wheel spin)
Thicker diff fluid (high number)
-Better braking in middle of corner (rotates)
-better steering for corner exit
CENTER
Thinner
-front wheels unload more during acceleration (to low = wheel spin)
-decrease on throttle steering (harder to steer when accelerating)
-better for rough tracks conditions
-car turns better out of corner
Thicker
-More all-wheel drive effect
-Better acceleration
-Increases on-power steering (reduces understeer)
-Better suited on high-bite, smooth tracks
REAR
Thinner
-Increases cornering traction
-Increases steering into corner
Thicker
-Decreases rear traction
Hope this helps a little.
Airlmeier4422 is offline   Reply With Quote
Old 06-01-2012, 01:23 PM   #3
JFuel11's Avatar
Trader Rating: 152 (100%+)
Default Good Answer
Well Answered....
Alan Bachman (AKA - Johnny Rocket Fuel)
Help your fellow racers go faster... You will have more competition!!!
Sponsors:
RC America - XRay - Hudy - Maclan Racing - Xpert Servos - Schelle Racing Innovations - AKA Racing Products - DE Racing - Sticky Kicks - Sanwa
JFuel11 is offline   Reply With Quote
Old 06-02-2012, 04:51 AM   #4
Helps alot, thanks
Old 06-13-2012, 07:09 AM   #5
polarbear72's Avatar
He did a great job with his answer. Nothing to add here
Mugen MBX7, Mugen MBX6TRR, Mugen MBX6E, Ninja, Murnan Modified Novarossi Bonito & Werks, Futaba, Tekin
polarbear72 is offline   Reply With Quote
Old 07-14-2012, 08:20 AM   #6
zmetal's Avatar
Just copied and saved, good answer 4422 what i was looking for.
zmetal is offline   Reply With Quote
Which 10th scale 4wd Buggy??? Speedy S Electric Off-Road 37 12-24-2013 04:41 PM
A-TECH BX-1 1/10 4WD BUGGY dailband Electric Off-Road 31 05-05-2007 12:45 AM
MRC / Academy SB Sport 4wd Buggy Cain Electric Off-Road 956 04-23-2007 07:56 AM
