Anatomy of a proper jump
I have a few questions about jumps. I believe that when I hit a single jump, to flat ground, I want to truck to land on all fours or at least with the front a touch high when i land. So, I need a little help with setup I think. What does it mean if I hit a single jump, say 12" high with a slope of about 45* and the back end comes up rapidly? Steady throttle with no bump before the jump. But then again, if I bump the throttle just on the jump, I get a good landing. I know it has to do with shock and spring setup but not real sure how to read it.
I realize i can adjust the attitude of the truck in mid air by tapping the brakes to bring the nose down or bumping the throttle to bring the nose up. I am just talking about how to read the suspension of the truck on a jump.
Oh, I am driving an SC10 4x4 FT kit. Don't know if electric and nitro are different.
Anyone got a good reference for jumps? Another thread possibly or link?
Thanks in advance,
Thanks in advance,
Adjust your shocks and springs for optimum corner speed, adjust your driving for jumps but you've already figured that out:
Sorry for the short answer but especially on my 4wd SC, I never tweak the setup for jumps, whether big or small, everything you need to do with the car can be done with your trigger finger.
Thats a great reply! Thanks! I hadn't thought about it but it makes sense. I can control the jumps somewhat so it makes sense to adjust for cornering. Thank you!
Got a few packs of practice and racing in. I see what you guys mean. It is easier to try and adjust mid air or before hitting the throttle instead of trying to set the truck up for a good jump. Now I just need to learn how to set my truck up for turns! lol!
My problem is the opposite of everyone else's. I always backflip and land on the roof.
Also if you are coming off the jump with the ass up in the air the chassis could be slapping and tossing the rear up as you start up the ramp.
Stiffer rear susp to keep from bottoming out on the jump.
Doing backflips off the jump is likely to be from staying on the throttle after you come off the jump... just keep it pegged and finish the backflip.
http://www.youtube.com/watch?v=fXhqgodBPIc&feature=plcp
Super Moderator
It means the jump itself is probably poorly designed/built if your going nose down off a one-foot jump that you're hitting with a steady throttle.
Very helpful posts, thanks!!!
Simple if your like this / hit the brake. If your like this \ hit the gas. If your like this - your good.
another question, if your car is starting to go nose first on the landing, how can you corresct it? giving it some gas or what?
Yup, to correct a nosedive, just squeeze the trigger.
Keep in mind that different vehicles will be able to correct this more easily than others, and if you were already at full speed, you won't get a correction, it'll just stop nose diving even more (see how to take off from a jump above if you can't correct enough un the air to come out of the nose dive).
