Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 02-02-2005, 04:01 PM   #1
Default Shut down
What is tha best way of stopping a nitro engine without a flywheel with the least amount of damage done to the engine ?
Tim
Stadium Trucker is offline   Reply With Quote
Old 02-03-2005, 06:10 AM   #2
rice's Avatar
Default Re: Shut down
Tim
push the filter towards the carb.
rice is offline   Reply With Quote
Old 02-03-2005, 04:28 PM   #3
ok kool thx man
Tim
Old 02-04-2005, 01:30 PM   #4
A3
Really? Is that the best way? How about pinching the fuel line or plugging the exhaut tip? Will this damage the motor?
A3 is offline   Reply With Quote
Old 02-05-2005, 10:14 PM   #5
Send a message via AIM to greencactus3
i have read sumwhere that pushing the filter in was bad. all the shit stuck the filter caught will be strained into the engine. i think you should cutoff the fuel supply. but then again i dont run nitros so whadda i know
greencactus3 is offline   Reply With Quote
Old 02-08-2005, 09:46 AM   #6
Send a message via AIM to glassman50
Post shut down
The best way to shut down a nitro engine is have the idle set with your throttle trim. Then all you have to do is turn the trim down it will close the throttle plate all the way and the engine will stop. Thats the way all the nitro plane flyers do it. It's the way I did it when I had planes. Always worked for me.
glassman50 is offline   Reply With Quote
Old 02-08-2005, 04:51 PM   #7
schmelme's Avatar
Thats fine if you dont have a brake on you vehicle. Every time you hit the brake the engine will die. The best way is to plug the exhaust tip. No damage will happen to the engine.
schmelme is offline   Reply With Quote
Old 02-09-2005, 03:56 PM   #8
RacingShack's Avatar
test
C.V.R.C. OffRoad, Southaven, MS
FT RC8.2E, Castle MMP, Savox, Airtronics
www.woodshackfurniture.com
RacingShack is offline   Reply With Quote
Old 02-13-2005, 10:41 AM   #9
I tried the blocking the Air-Intake method with the filter on and off...
I discovered that with the air-filter off... I burnt my finger. With the air-filter on... my hands got all oily from the air-filter oil. I've looked around and found that the most effective way was to starve the engine of fuel... by pinching the fuel line.
ajlim is offline   Reply With Quote
Old 02-13-2005, 11:51 AM   #10
fmevans's Avatar
the best way to stop a nitro engine is either to stop the flywheel with the tip of your shoe if you can get to it. this is hard to do for t maxx users or simply to pinch the fuel line. your nitro will idle up and then die within a few seconds.
fmevans is offline   Reply With Quote
Old 02-13-2005, 02:45 PM   #11
Nrctc3's Avatar
Send a message via AIM to Nrctc3 Send a message via Yahoo to Nrctc3
Dont push the air filter, it forces dirt into the engine. I've always tapped the flywheel or plugged the stinger on the pipe. They say it may cause it to flood, but I never had that problem.
Nrctc3 is offline   Reply With Quote
Old 02-13-2005, 02:48 PM   #12
RCNitroDude999's Avatar
Trader Rating: 26 (100%+)
i sometimes use my shoe, or the other end of a screwdriver and press it against the flywheel, stops the engine quick and easy.
RCNitroDude999 is offline   Reply With Quote
Old 02-13-2005, 02:49 PM   #13
Nrctc3's Avatar
Yep, or I use my finger. Dont mess-up or else you'll
ok i cant keep my mouth shut rc31cli Georgia Racing 3 08-29-2008 10:06 PM
upside down car = shut off ruggydriver Nitro Off-Road 7 08-22-2008 06:41 PM
Shut up Chris!!!!!!!!!!!!!!!! westerdude42 Northwest Racers 1 05-11-2006 01:14 AM
Spektrum - GTB Glitch/shut down Takt Electric On-Road 13 03-22-2006 08:33 AM
Best way to shut off engine? CoaterCup Singapore R/C Racers 11 10-12-2003 09:11 PM
