Go Back  R/C Tech Forums > General Forums > Rookie Zone
Wont Stop Glitching...  Do I Need Spektrum? >
Old 02-13-2005, 12:02 PM
Nrctc3's Avatar
Angry Wont Stop Glitching... Do I Need Spektrum?
I've been fighting this glitching problem in all my cars for a while now. I'm using a Hitec SRX transmitter sent it back and got a new one and it still glitches. I've tried switching channels, esc's, motors, batteries everything. It does it in all my cars on the same point lap after lap at the track... Any ideas? Will a Spektrum system solve my problem? Is it compatible with the SRX?
Nrctc3 is offline
Old 02-13-2005, 01:42 PM
RCNitroDude999's Avatar
Trader Rating: 26 (100%+)
you need futaba
RCNitroDude999 is offline
Old 02-13-2005, 01:43 PM
Nrctc3's Avatar
I need to quit being such a "rookie" & stop posting in the rookie section
Nrctc3 is offline
Old 02-13-2005, 01:45 PM
Post in the electric forum, more people browse there and you will probably get help quicker.
Old 02-13-2005, 01:51 PM
Nrctc3's Avatar
Dont boss me around!
Nrctc3 is offline
Old 02-13-2005, 01:53 PM
dont talk back to your daddy like that son
Old 02-13-2005, 01:54 PM
Nrctc3's Avatar
Sorry, dont tell Momma
Nrctc3 is offline
Old 02-14-2005, 10:05 PM
Default Re: Wont Stop Glitching... Do I Need Spektrum?
I've seen a number of people with the same problems ..All I can say Is they All went with differant manuf, and have no problems .. Its up to you ,,,
Can't Have Fun If It Don't Work .....
mb racer is offline
Old 02-15-2005, 08:39 AM
Default Glitching !!!
Better of switching manufacture !!!! I went through a long and expensive route with my radio set !!!In the end changed over from a KO stick to a futaba 3VC zuper........no more problems !!!!
Cya
xtreme888 is offline
Old 02-15-2005, 10:35 AM
Suspended
Trader Rating: 14 (100%+)
Try standing in a different spot. If that doesn't work, wrap your head in foil, do ten jumping jacks, spit on the nearest person, then recite "Mary had a little lamb" backwards. That should fix your glitching problem.
Phatkat is offline
Old 02-15-2005, 11:46 AM
Cole Trickle's Avatar
....It does it in all my cars on the same point lap after lap at the track...
What so special about that point? I believe the other racers dont have the same problem? And they dont run the Spektrum, right?
You wrote "everything", so please forgive me asking: Have you soldered the small caps on your motors? Have you tried moving the RX and antenna as far as possible away from the motors?
And at my experience, the "minus-power-wire" usually carry more noise and sometimes moving that wire just 1 centimeter makes a difference....
Can you show a pic of your car, maybe we can guide you about the wiring?
Which other stuff than the SRX are you using / have tested with?
By the way, at my experience, my Hitec HFS-04MI+ is more glitch resistant than my KO KR 297 Z
Cole Trickle is offline
Old 02-15-2005, 02:20 PM
TL_XXX-S_racer's Avatar
Well what alot of people tell me is the crystal could be bad, or u can try putting more capacitors on the motor. the pre-build ones on the motor could be bad. Those would be my 2 things to try.
Hope it helps
TL_XXX-S_racer is offline
Old 02-15-2005, 04:45 PM
howard hudson's Avatar
order this from speedtech and all your glitching will be gone
http://www.speedtechrc.com/store/ebp...nid=64&id=2193
howard hudson is offline
