Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 01-30-2005, 11:12 AM   #1
Default new again after 12 years a little would be great
Okay I'm getting back into the rc scene . I picked up an rc12l4. IT came with 7 packs. there orion GP3300 ni-ph. I curious what the best way to charge these guy's. I've read that discharging Ni-ph isn't good. So what do you guy's recommend. I still have to purchase a charger. I do now I need one that can peak charge.
cyrrus is offline   Reply With Quote
Old 01-30-2005, 03:23 PM   #2
nmt6789's Avatar
Send a message via AIM to nmt6789
You mean nimh rite? Charge at 5.0 amps
nmt6789 is offline   Reply With Quote
Old 01-30-2005, 03:24 PM   #3
should i discharge the packs too.
Old 01-30-2005, 03:32 PM   #4
nmt6789's Avatar
Yea discharging wont hurt them...
Old 01-30-2005, 07:04 PM   #5
cool thanks heard from some you should'nt and some you should
Old 01-30-2005, 10:47 PM   #6
Whether you should discharge the packs or not also depends on the pack configuration. If they're stick packs, with the cells arranged end-to-end, DON'T discharge em. You'll be pulling amps from the two end cells and could reverse-charge em. The discharger can't tell if this happens, but it'll lower the output voltage and life of the pack.
If they're side-by-side, they'll be fine if you just use a discharger board that'll drain each cell seperately.
Liko is offline   Reply With Quote
Old 02-15-2005, 09:25 AM   #7
cool thanks. I"m running side by side in 4 cell conf.
Old 02-19-2005, 10:37 AM   #8
Nrctc3's Avatar
Send a message via AIM to Nrctc3 Send a message via Yahoo to Nrctc3
Discharge them after every run, then recharge them again. If you're going to store them, then just leave atleast 50% charge in them.
Nrctc3 is offline   Reply With Quote
How many years have you been into RC? RCSteve93 Chat Lounge 127 11-06-2007 08:22 AM
It's been about 15 years dustyz Rookie Zone 19 10-08-2007 02:19 AM
It's been 20 years Scrogg Electric Off-Road 20 09-06-2007 05:38 PM
20 Years ago ssdrop64 Chat Lounge 35 08-07-2005 05:07 PM
Out of R/c's for about 2 years... cdan2031 Electric On-Road 1 03-27-2005 03:54 PM
