Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 03-27-2012, 02:44 PM   #1
sprintkat's Avatar
Default Racing Pan cars on pavement
I am setting up a pan car to race on pavement can anyone help with tires that would work best ect. thanks
sprintkat is offline   Reply With Quote
Old 03-28-2012, 08:38 AM   #2
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Generally, softer compounds are better on asphalt. I always used either Green or Pink fronts with White or Green compound rears on pavement.
You can also feel free to post pan car questions here as that's a good thread to get answers to these kind of questions.
MarkA is offline   Reply With Quote
Old 03-28-2012, 09:21 AM   #3
tbrymer's Avatar
Default Tires
Depends on the track and the condition of it. If it is a prepared asphalt that has been blown off and soda laid down on it, you may be able to go with a harder compound of foam, howver if it is not prepared you will probably have to go software. At my local track that is an oval asphalt track, I use bsr tires. Some people use purple compound all the way around and others like myself use the following: RF - double purple, LF - purple, RR - purple, LR - double pink.
I hope this helps.
tbrymer is offline   Reply With Quote
Old 03-28-2012, 09:44 AM   #4
Moderator
MarkA's Avatar
To clarify, my answer assumed onroad, whereas the above answer is a good one for oval.
Old 03-28-2012, 03:21 PM   #5
tbrymer's Avatar
Default Pan Car
Very true, I made the assumption of oval
Tamiya 1/12 R/C RM-01 "Racing Master" RedBullFiXX Electric On-Road 1170 09-13-2017 06:28 AM
5280 Raceway - Colorado On Road RC Club (CORRC) SlamMan Colorado Racing 21404 05-01-2017 07:55 PM
1/10th pan car Taz_S Oval, Larger Scales and More 16138 09-25-2014 09:03 AM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
