Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 03-23-2012, 08:37 PM   #1
Default savox 1258 and a aluminum steering
im gona get a savox 1258 and im gona put a aluminum steering thing in it forgot what it was called and i heard if you higt something hard with it an the servo saver isnt there it will break the servo. My question is would savox cover this and for how long and if not what would it break exactly inside the servo and could you just replace that part
chancejeff is offline   Reply With Quote
Old 03-24-2012, 04:06 AM   #2
SolderGlob's Avatar
More than likely you would strip the gears and those can be replaced. Question is, why wouldn't you run a servo saver?
Losi Nitro SCT···Losi 3-shoe clutch···125 cc tank mod···Savox 1267(st)···Savox 1257(th)
Losi 810e···CC 1415···MMP···3s LiPo···Savox 1268
SolderGlob is offline   Reply With Quote
Old 03-25-2012, 08:52 PM   #3
i was told with the aluminum steering rack i have it would take away the servo saver so i didnt put it in because of i was afraid of ruining the servo or could u suggest and better steering racks for the b4 that dint take away the servo saver
Old 03-26-2012, 02:42 PM   #4
Super Moderator
Depends on how you are using the B4, and your personal comfort level, but many experienced racers run 2WD buggies without servo savers. A lot of B4 guys glue it together or eliminate it because of issues. The TLR 22 doesn't even have a saver.
While it can seem risky, the front of a 2WD buggy is pretty light, combined with modern stout metal geared servos it seems to work reasonably well. Can help "walk" away from a pipe if you get stuck at an angle. Be smart about it of course, if you end up jammed under a pipe with the wheels forced over hold the steering over until marshaled, etc.
But if you aren't comfortable then keep the saver setup, and check it occasionally.
Dave H is offline   Reply With Quote
Old 04-01-2012, 06:54 PM   #5
excellent advice Dave !
Killer Bee 1 is offline   Reply With Quote
Old 04-01-2012, 06:59 PM   #6
Last I heard savox does not warranty stripped gears at all so you are on your own to replace them if they break.
newspeed is offline   Reply With Quote
FS/FT Kyosho SC (Ball diff,Velvets and more) Manatarms25 R/C Items: For Sale/Trade 14 12-13-2011 05:23 PM
+++ CHEAP ($550!) RC8T w Orion MTE CRF Motor - 2050 - SAVOX SERVOS - LiFe - MORE +++ devnull R/C Items: For Sale/Trade 13 08-31-2011 07:12 PM
