New Motors for nitro Cars?
I am looking to get a new motor for my 1/8 OFNA Hyper Sprint Car. I am looking at the Losi 8ight 2.0 T Truggy RTR 454 complete Nitro .28 Engine. It has the Macstar.28 6 Port Engine on it now. Are all Nitro Motors interchangeable? Cause I am having problems with the Macstar and I am thinking of just putting a new one on it and want to make sure it would work first.
no they are not. if i remember right, with the 1/8 motors some have threaded ends on the crankshaft and others use a e-clip to retain the clutch bell. the ARE NOT interchangeable without modifying the trans or endbell. i suggest heading into your local hobbyshop and asking someone that is knowledgeable with nitro vehicles.
PS: Add check pullstart or bump start as a pullstart has a different rear backplate and crank.
All engines arent equal!
So I was checking online and I looked up the OFNA Hyper Sprint that is 80% prebuilt and it says that it needs a big block motor. So Does that mean that you could find a "Big Block" and it should bolt up? Cause I blew the piston in this one and it'll be better to just replace the engine. I would be paying about $80 for the piston, sleeve, and rod when I can get a brand new motor on ebay for about $120-$140.
