Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 02-04-2012, 04:17 AM   #1
3Q
3Q's Avatar
Default Want to try on road, need advice
Hi there, I race an sc10ft on a weekly basis and always make the A main. I live close to a new outdoors on road track and would like to have a go at it. I probably won't race but would like to turns some laps just for fun. What car should I go for? Must be fun to drive and durable. I have been offered a Ken Block 1/16 Traxxas for a good price but have read mixed reviews. Will i be happy with it (I'm used to driving SC 2wd that have less than perfect handling) or should I look at a TC or 1/12 pan car? Some experienced feedback would greatly appreciated.
Kris
Team Associated SC10FT
Team Associated SC10 RTR
Hot bodies VE8
3Q is offline   Reply With Quote
Old 02-04-2012, 09:48 PM   #2
Moderator
MarkA's Avatar
Trader Rating: 21 (100%+)
Kris
Pan cars don't run well outdoors unless the surface is cleaned/prepped regularly. They're a lot of fun but they hate dust.
The Traxxas is more like a toy.
It sounds like a used touring car would be something that'd work out well for you.
MarkA is offline   Reply With Quote
Old 02-04-2012, 11:41 PM   #3
blis's Avatar
Kris
Well considering you are in the same city as I am, it's Touring car all the way... There's not much Pan Car racing unless you want to just join in on the 10.5 Superstock outlaw class at Brendale every other friday night. Kerry there would tell you a Top Photon is a great car as well.
(You can also save a HEAP on tyres running the foams that we throw away from the Nitro Tourers. Always happy to hand out foams that are bordeline for my Nitro)
Or, head out to Bayside / Capalaba BRCCC on a weekend when they are racing and hunt around for a used Xray TC3
OzRC at Geebung has a few clones and 2nd hand cars and a full array of batteries, ESC's tyre etc.. Best of all, check out what the others are saying in regard to 2nd hand parts and availability. Jeff at Trackside may have some second hand ones as well, but beware of parts availability regardless of where and who .
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 02-05-2012, 04:40 AM   #4
3Q
3Q's Avatar
Thanks for your replies, a used X-ray might be the way to go, I'm going to check out a race meeting at Bayside and Meakin Park and see if it's what I want to get into. I'll pass on the Traxxas though.
Cheers
Hot bodies VE8
Old 02-18-2012, 06:37 AM   #5
rosko's Avatar
Get an associated tc6 best choice, parts are easy to get very good car
rosko is offline   Reply With Quote
Old 02-18-2012, 08:50 AM   #6
locked's Avatar
Used cars can be good or bad. You might get a great deal or have to find and replace worn or damaged parts and maybe spend in total as much as a new kit.
Almost every brand has a high end car capable of winning if set up well and driven by a great driver. XRAY's precision and overall quality of parts are as good as it gets, but you do have to pay a little more for everything. They have a fairly wide setup window and they are arguably the most durable, but all cars wear parts (some more than others) and all will break, given the right amount of force and angle of impact. All can also be beefed up to minimize damage from lesser impacts. A stiff bumper can help tremendously.
In on-road, minor set up changes can make huge differences to the handling. Just getting it properly aligned with even left and right steering, precise camber, precise droop and well built shocks, is extremely important. The car should also be balanced perfectly left to right. Front/rear balance can make a major difference in handling as well. I like the weight very close to center, but just slightly tail heavy. Others like it heavier in the front or perfectly centered.
Once you get a base setup that you feel comfortable driving, adjust things in very small increments from there. The right tires and tire prep can make a massive difference. When the car handles well, you'll love it. When it doesn't handle well, it can be a challenge to figure out.
Best of luck
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 03-26-2012, 01:17 PM   #7
sprintkat's Avatar
I would get a used TC3 Very good durable car.
sprintkat is offline   Reply With Quote
GT8 Class--buggy-based on road electric! snrscion Electric On-Road 3421 08-23-2017 10:26 AM
**NSWRCRCC Inc. - Moorebank On-Road** VenomWorldOrder Australian Racing 11441 07-19-2017 03:19 AM
GT class--buggy-based on road! duneland Nitro On-Road 9643 11-16-2016 03:11 AM
Region 4 Dir. and On-Road Guys punkracer24 Florida Racing 16 08-29-2007 07:58 AM
