Go Back  R/C Tech Forums > General Forums > Rookie Zone
What is the best grease >
Old 12-10-2011, 08:41 AM
MyRc_'s Avatar
Default What is the best grease
I have a losi 8ight 2.0
I'm trying to find a good grease out there for the differential ring gear and the pinion gear not the diff oil that goes in the differential..I hope it makes sense...
MyRc_ is offline
Old 12-10-2011, 09:57 AM
Losi Grease <LOSA99203>
ivan b is offline
Old 12-10-2011, 10:10 AM
grease collects dirt, so I use thrust bearing lube
minilantern is offline
Old 12-10-2011, 05:13 PM
Trader Rating: 21 (100%+)
FWIW, I use AE black grease.....
Duster_360 is offline
Old 12-10-2011, 06:25 PM
MyRc_'s Avatar
Thanks guys...
MyRc_ is offline
Old 12-10-2011, 10:19 PM
GRANPA 67's Avatar
Trader Rating: 32 (100%+)
http://tkocompetitiondev.com/product...roducts_id=343
I use this stuff called Eureka lube(EL-1), you can get it through TKO link above.
GRANPA 67 is offline
Old 12-12-2011, 05:32 PM
BackTrack's Avatar
+1
BackTrack is offline
Old 12-14-2011, 02:54 PM
I use motorcycle chain lube. Repels all dirt.
modelfan is offline
Old 12-14-2011, 09:45 PM
coopsnard's Avatar
AE black grease.
coopsnard is offline
Old 12-14-2011, 09:55 PM
jwmustang's Avatar
Green Grease.
jwmustang is offline
