Big Brute restore
Big Brute restore
Trying to restore an old Kyosho Big Brute and I need some suggestions on a compatiable esc and motor. Any help would be greatly apperciated.
If you want something more modern to acutally use the truck, something like this will probably be enough power to make that truck do wheelies.
That seems easy enough. Apperciate the help. I also have an old Kyosho Optima 4wd car that I would love to go with a brushless motor on it. Other than upgrading the motor and esc would there be anything else needed? Such as changing/upgrading the chain drive or gears? Would like to get that car to fly. Thanks again for all your help.
Depending on your batteries, you may want to go lipo as well but old packs will power a brushless setup and it'll be faster/better/run longer on the same packs than brushed would have.
