M11 binding help!
M11 binding help!
I have an m11 radio with the Sanwa 93824 module and 92624 receivers I got the setup used and I am having troubles binding. The manual I have doesn't explain how to bind the rx and tx it's for the 75mhz. Please help I posted this in the radio section and got no help. Thanks for any advice if you have some.
I cannot find the binding button on the m11, not the m11x but just the m11. Does anyone know how to bind it or where the binding button is?
M11 will need and FHSS (or DSS) module to be 2.4 compliant. I think the latest they made was FHSS-2. Without an FHss/DSS module and compatable receiver the M11 is a crystal based radio. so NO binding button oin the radioi (it is on the module if you have the correct one for 2.4
isn't the bind button on top of plug in module. Under the air in airtronics?
