1/8 Buggy Question
1/8 Buggy Question
Do the 1/8 scale cars need 2 receivers? I'm browsing around and it seems there is one for throttle and one for steering. Is that true? If so, why?
Electric R/C's typically just have ONE servo (which controls steering). The forward/reverse/brake action is all controlled by the ESC (electronic speed control).
Some larger electric R/C's may have 2 or more servo's... For example. The Losi XXL runs dual steering servo's and another servo for forward/reverse selection. So in that case, an electric would have 3 servo's and an ESC.
More often than not, electric R/C's just have one servo for steering though.
Yes 2 required for nitro only, on most electric buggies the brakes are controlled by the esc.
If you're unsure of the specs on a certain vehicle, just download the user-manual from the supplier's website. You'll be able to learn the "ins and outs" of the vehicle directly from the manufacturer that way.
I'm no Mugen pro, so I don't want to tell you how many servo's it requires... I can assume only one for steering, and then your ESC.
