Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 03-08-2011, 10:46 AM   #1
Default cogging-glitching?
Ok got a ?. got a used esc/motor combo for a ultima sc it's a sidewinder/5700kv . dont plan on using the motor for racing yet, buuuuttt wanted to make sure it worked and see what the truck woud do. Well sh#%$# its fast. But at light throttle it jerks quite a bit little more throttle and its fine. Then at full throttle and at a slight distance motor seems to go on and off and i am holding full throttle. I am gessing that is glittiching but what the cure? the other is cogging? or normal? My gears are 19/78 and 2.6 trans or wrong gearing. I tried a 16t gear and didn't seem to mesh right. Any way could cogging and glitching be defined and maby some poss. cures thanks
Knew is offline   Reply With Quote
Old 03-08-2011, 12:42 PM   #2
bigben1165's Avatar
Send a message via Yahoo to bigben1165
you might want to call the manufacturer (castle) about that one, you may have gotten a bad unit.
BigBen
HPI TEKNO VORZA, 2200kv, 6s maxamp, MMM, 4PKS, huge balls
bigben1165 is offline   Reply With Quote
what causes cogging losi316 Rookie Zone 8 04-18-2010 11:36 AM
my keeps glitching/twitching!! what do i do? mytto1 Electric On-Road 18 12-02-2009 08:58 PM
Mamba Max Cogging mattnin Electric On-Road 42 05-10-2007 08:47 AM
