Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 03-02-2011, 02:56 PM   #1
FLATLINE XTR's Avatar
Default Batteries batteries batteries!!!
What is the largest battery my stock 3605 stampede can handle safly?
FLATLINE XTR is offline   Reply With Quote
Old 03-03-2011, 01:07 PM   #2
bigben1165's Avatar
Send a message via Yahoo to bigben1165
largest as in number of cells? or mah? are we talking lipos?
BigBen
HPI TEKNO VORZA, 2200kv, 6s maxamp, MMM, 4PKS, huge balls
bigben1165 is offline   Reply With Quote
Old 03-03-2011, 01:15 PM   #3
jamie.21's Avatar
If your talking lipo, I would start with a 2 cell lipo, the mah is basically how long your run time should be.
jamie.21 is offline   Reply With Quote
Old 03-03-2011, 04:01 PM   #4
bigben1165's Avatar
cell wise, traxxas single pack vehicles (stampede, bandit, etc) can run a max of 3S lipos unless you upgrade your electronics.
BigBen
Old 03-03-2011, 04:41 PM   #5
I have the old version of the stampede will that still handle the lipid? And by largest I meant mah or most powerful. Iguess I could ha e said that sorry.
Old 03-03-2011, 06:55 PM   #6
bigben1165's Avatar
in that case you need to look at the specs for your speed control and your motor. they will tell you the biggest voltage that your stampede can handle. look at the traxxas website if you dont have the manual for the truck or components. let me know what you find.
BigBen
Old 03-03-2011, 09:33 PM   #7
T. Herwig's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to T. Herwig
The 3605 stampede uses an XL-5. The largest you can go is a 2S lipo, but be careful. There's no low voltage cutoff.
Tyler Herwig
Tekno RC teknorc.com ∙ JConcepts jconcepts.net ∙ Spider Hobbies spiderhobbies.com ∙ SMC smc-racing.net ∙ Upgrade RC upgrade-rc.com ∙ Kustom RC Graphics kustomrcgraphics.com
T. Herwig is offline   Reply With Quote
Old 03-04-2011, 06:44 AM   #8
It says input voltage is 4 cells to 8 cells (4.8-9.6v). It also says motor limit 15 turn (540) 12 turn (550). Is that what you are asking about?
Old 03-04-2011, 07:27 AM   #9
blis's Avatar
The battery power is only relevant in terms of voltage. The motor will draw only the current it needs. There is correlation of current and voltage, hence the more current your battery can store (in the case of NiMH) the higher the initial voltage of the battery.
A 5000mAh (5amp) 7.2 NiMH battery will at full charge be close to or slightly over 9V so you are within your specifications.
Also, the higher current batteries are slight fatter, so space may be an issue, but unlikely.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 03-04-2011, 07:33 AM   #10
bigben1165's Avatar
yeah, sorry, i mispoke, you can only use a max of a 7 cell nicad or 2S lipo battery. traxxas does have a program where you can trade in your power system for some money off a new more powerful system. its a pretty good idea!! look into it!
BigBen
Old 03-04-2011, 04:29 PM   #11
Awesome! That is exactly what I wanted to hear! Thanks everyone! I will definatly lookinto that.
Old 03-04-2011, 04:33 PM   #12
Now for novice racing do you think that I should upgrade to a brushless system or do you think that I will get my butt handed to me so bad that it wont be fun with the stock setup. But different gears.
Old 03-04-2011, 04:46 PM   #13
Sorry here's another question...are one of the no name hong kong batteries ok to use for now? And also will I lose any power in the traxxas high flow to whatever the white end is called? One more question is it ok to hook up 2 5000 mah to the truck or will that be too much?
Old 03-04-2011, 04:57 PM   #14
T. Herwig's Avatar
www.hobbyking.com
The Stampede only has room for 1 5000mah pack.
Tyler Herwig
Old 03-04-2011, 07:04 PM   #15
It has room for like 3 or 4 of them but doesn't have the equipment for more than one. I have already built a stack plate for it so that it can hold 2 and air still get to them. Very top heavy though. I will have to go it to depth a little more on another design. But I am only going to waste the time if the factory equipment will handle 2 5000s or 4000s. Will that be too much for the motor and esc?
Batteries, Batteries, Batteries Hunter R/C Items: For Sale/Trade 6 03-23-2008 10:12 AM
Batteries Batteries Batteries ldp787 R/C Items: For Sale/Trade 13 01-30-2008 07:10 PM
Batteries, Batteries, Batteries M.J Electric On-Road 34 10-24-2005 09:45 AM
batteries batteries batteries mmatic Electric On-Road 23 10-08-2004 11:29 AM
