Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 03-01-2011, 10:29 AM   #1
Default Castle ESC cutout
I race an SC10 with the Sidewinder SCT combo and Lipo packs. Occasionally, if I land heavily after a large jump, I lose throttle completely for maybe 10 or so seconds. Steering is fine, it is just the motor. I suspect that something is causing the ESC to re-boot. My first thought was a loose connection, but I cannot see anything loose. Is it worth swapping out the receiver? Could something there be causing an issue?
cslewis is offline   Reply With Quote
Old 03-01-2011, 07:35 PM   #2
Trader Rating: 21 (100%+)
If yoiu've been tru the connections and are satisfied its not one of them causing the prob, try swapping the rcvr. If that doesn't fix it, then its time to call Castle, seems you might have a connection prob in the esc.
Just curious, but have you looked at the esc LEDs when the power's gone? There may be a clue in what the LEDs are saying.
Duster_360 is offline   Reply With Quote
Old 03-02-2011, 06:28 AM   #3
Thanks for the reply, trying a new receiver is my next step. The problem I have with looking at the LEDs is that by the time I get to the truck from across the track, the ESC has booted up again and throttle is restored.
Old 03-02-2011, 09:40 AM   #4
this happened to me last night at my local track and i instantly thought about your post. i also run a castle setup. i figured out why mine did it. i borrowed a battery from a friend while mine was charging. his was pretty beat and the bannana plugs that go into the lipo wern't tight anymore and any impact would cause one of them to lose connection and reset my esc. check that out on yours. (assuming you are running a lipo as well that it)
bobbydz is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
Robitronics Scalpel 1/18th Pan Car? oXYnary Micro and Mini Scales 1271 04-20-2016 09:10 AM
Castle Creations Mamba Max Pro Sensored ESC bkspeedo Electric On-Road 1512 12-24-2014 08:06 PM
HELICOPTERS R US Turtlemaster Northwest Racers 967 03-06-2008 01:52 AM
