Go Back   R/C Tech Forums > General Forums > Rookie Zone
Old 02-27-2011, 12:51 PM   #1
Default What type of battery connector does the MRC ZRT-1 use?
Hi,
I was wondering if anyone knew what type of battery connector the MRC ZRT-1 uses and if there's a banana plug to (?) adapter for the batteries.Thanks for your help.
Chris
CRed is offline   Reply With Quote
Old 02-27-2011, 05:17 PM   #2
Trader Rating: 21 (100%+)
The only god pic I can find is the one on Stormers ad. It shows the supplied hard cased lipos connect with bullets like a typical hard cased lipo does, prob 4mm, thats about as standard as anythingin this hobby gets.
The esc uses bullets (should be 4mm male bullets) that connect with the harness supplied with those hard cased lipos which has a charging/balancing harness builtin. I can't see enough of it to know what type connector is used for the chargers balance port.
Duster_360 is offline   Reply With Quote
What type of battery connector does the MRC ZRT-1 use? CRed Electric Off-Road 7 04-20-2012 07:13 AM
